Question about AEG Washing Machines
Lavamat 86820 error code CE. have checked the cogs and the area of water entry all seems ok but water still not coming into machine. have not been using powder dispenser for some time now so don't understand the problem. help. nicole
5 Suggested Answers
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at  www.repairclinic.com
Posted on May 06, 2009
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
Jahn27
  • 1554 Answers
SOURCE: aeg 86820 update lavamat. stoped
This error code is pertaining to a drive motor particularly the carbon brushes which connect to the motor commutators and provide power for the motor. Check the condition of the carbon brushes and replace them if worn out. This video should give you an idea what a carbon brush is and how to replace it.
The video shows a different brand of washing machine but they are basically the same.All you have to do is take the top panel off if removing the rear access panel requires it. Remove the drive belt then take the motor out and replace the carbon brushes.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 05, 2011
What means Error Code CE on a AEG 86820 Update washing machine?
The water distributer is out of order there are little plastic wheels 3 of them one orange, yellow and white, the orange is most likely stuck so you have to replace the hole water distributer app. $ 100.00 for the part.
Jun 07, 2014 | AEG Washing Machines
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Jul 04, 2009 | AEG Washing Machines
My AEG lavamat 74620 doesnt fill up with water
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
May 06, 2009 | AEG Lavamat 72640 Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
