Question about Compaq Presario CQ60-220US PC Laptop
Hi, I have recently exchanged the keyboard and now only the shortcut keys work. i.e. when I press "e" the "edit" window opens. What should I do?
  • 415 Answers
Two possibilities that cause this problem:
1. the data ribbon is not in right. Recheck the data ribbon (connection ribbon)
2. the function key might be stuck down. It may appear to be up but still be stuck in contact position as if held down
It is more likely the first thing so check that first. I'm assuming you matched the particular model compaq when getting the keyboard?
Posted on Apr 05, 2011
Tip
Windows 8 keyboard shortcuts Knowing at least some of the Windows 8 keyboard...
Knowing at least some of the Windows 8 keyboard shortcuts helps make your Windows 8 experience much more enjoyable. Try to memorize these top Windows 8 shortcut keys.
Press the Windows key to open the Start screen or switch to the Desktop (if open).
Press the Windows key + D opens the Windows Desktop.
Press the Windows key + . to pin and unpin Windows apps on the side of the screen.
Press the Windows key + X to open the power user menu, which gives you access to many of the features most power users would want (e.g. Device Manager and Command Prompt).
Press the Windows key + C to open the Charms.
Press the Windows key + I to open the Settings, which is the same Settings found in Charms.
Press and hold the Windows key + Tab to show open apps.
Press the Windows key + Print screen to create a screen shot, which is automatically saved into your My Pictures folder
on May 16, 2015 | Microsoft Windows 8.1 - Windows
Tip
Shortcuts tricks for Windows Vista(Keyboard shortcuts)
Following are some of keyboard shortcut tricks for Windows Vista and also for Windows XP:
  • Window key+B: Sets focus to first icon in the notification area. You can use arrow keys to move among the icons in the notification area or press Tab to move around on the task bar.
  • Window key+D: Show Desktop (without the Sidebar).
  • Window key+E: Windows Explorer (opens to Computer).
  • Window key+F: Find Files or Folders (aka Search).
  • Window key+M Minimize All windows (Sidebar not included).
  • Window key+Shift+M: Undo Minimize All Windows.
  • Window key+R: Open the Run dialog box.
  • Window key+Tab: 3-D Flip (flips you through your applications but with a cool graphic instead of the standard Alt+Tab). Requires the use of the Aero user interface.
  • Window key+Pause/Break: System Properties.
  • Window key+F1: Windows Help.
  • Window key+L: Locks workstation. If the user account has a password, it must be reentered to unlock the system again.
  • Window key+U: Ease of Access Settings.
  • Window key+ Spacebar: This shows the Sidebar (the Sidebar must be open, but minimized).
  • Ctrl+Window key+Tab: Brings up Flip-3D, but it will stay on the desktop so you can scroll up, down, left and right.
  • Window key+T: Allows you to tab between application buttons on the task bar.
  • Ctrl+Shift+Esc: Opens Task Manager more faster than alt+ctrl+del.
  • Alt+Tab: Windows Flip. Allows you to choose an open application to switch to by repeatedly pressing the Tab key.
  • Window key+5: opens the snipping tool.
Some User Logging Shortcuts:
  • Window key (and then) three right arrows and Enter To Shut down
  • Window key (and then) three right arrows and U To Shut down
  • Window key (and then) three right arrows and R To Restart
  • Window key (and then) three right arrows and W To Switch Users
  • Window key (and then) one right arrow and Enter To Sleep
on Jan 16, 2010 | Microsoft Windows Vista Ultimate Edition
The keys on the keyboard on my sony vaio vgn-t350 are malfunctioning, for example when I press "m" the windows will minimize and when I press "f" the find window will appear and all...
hello there go to control panel then open accessibility options then on the keyboard tab uncheck the use sticky keys or all uncheck the option on keyboard tab.
Dec 11, 2010 | Computers & Internet
I have a zd 7140us from HP my keyboard is messed up. When I press certain keys it opens other thngs. For example: if I press key "w" key "8" or ""u" the window...
if the keyboard is fine and you checked on other computer then it shows that the application you are working has gone corrupt, try to re-install OS and application software.
Also try to check with USB/External Keyboard..
Nov 24, 2010 | HP Pavilion ZD7140US Notebook
I HAVE VAIO VGN FS630/W Originally came with 32 bit windows xp home edition . I just upgraded to 32 bit windows 7 professional. I'm unable to use the vaio hot keys (Fn key plus "F" key) that...
Look in the control Panel under the keyboard icon.
Check you have the correct keyboard setup.
The sony utilities to set the function keys should also be there.
Nov 09, 2010 | Sony VAIO VGN-FS630/W Notebook
My mouse is NOT working but the keyboard is....HELP I can not access the online manual because the mouse doesn't work and I don't know how to manually work the keyboard......
Here is a list of shortcuts for IE. Here is a list of key board shortcuts for windows.
You could use mouse keys by configuring the key board. How to configure mouse keys: Here. In Vista (you haven't specified your OS) Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Control the mouse with the keyboard, select:
  • Turn on Mouse Keys.
  • Turn on Mouse Keys by pressing ALT+M.
This has two or may be 3 posts following this since its too long
Jun 04, 2010 | Microsoft Wireless Optical Desktop Comfort...
Turn off shortcut keys
Hi...
There are two way to do turn off shortcut.
  1. Press the Window in the keyboard and press letter U twice.
  2. Press ALT F4 and press letter U.
Those are the two shortcut keys.
Thanks for using fixya
PCmania
Aug 03, 2009 | EzKey EZ7000 Smart Office Keyboard PS2
How do i get a screenshot??
Hi!
1. Using Print-Key of your keyboard
Open the window from which you want a screenshot and press "Print".
Open e.g. M$ Word and press CTRL + V to paste it in.
2. Use the freeware tool ZScreen "http://brandonz.net/projects/zscreen/".
Hope I could help.
See ya,
Christian
May 08, 2009 | Microsoft Windows XP Home Edition
In Word
Hi check here http://www.statisticalexperts.com/forum/redirect.php?goto=newpost&tid=5 Good Luck.
Aug 25, 2007 | Microsoft Office Standard for PC
Compaq Presario CQ60-220US PC Laptop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
