Question about SanDisk Sansa e270 MP3 Player
Recover error in i pod and key lock model no e260
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
There's a slide switch on the top of the unit, near the headphone jack. Slide it away from the jack to unlock the unit.
Posted on Apr 05, 2011
My sansa e260 says load main screen fail switch to recovery mode...what do i do?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa.
http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related
here is a link to a kid showing you how to go to recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Usb mode in settings MSC is best, Updater recognizes it in this mode
Jun 26, 2010 | SanDisk Sansa e260 MP3 Player
When turning on the Sansa e260 it is now in the Key LOCKED mode
I had a similar problem with my e250. The problem was that one of the plastic arms on the lock switch had broken off. The one that locked it was still in place but the other wasn't, so I could always lock it but never unlock it.
Since you already know how to open the case, take a look at the switch at the top. Use a pen or something and slide it to the unlocked position (away from the headphone jack). Put it back together and see if it works. If it does, just remember never to lock it again.
Mar 10, 2010 | SanDisk Sansa e260 MP3 Player
240d mercedes. automatic door locks seldom work.
Very common. The rubber diaphrams and checkvalve o rings do not last forever, and they begin to leak. The most common one is the driver side's vacuum door lock valve. This one is activated when your key turns the lock and diverts the valve's vacuum, which activates the other door's plungers to open. This is the one to fix first, and it requires that you remove the inside door hardware and panel to reach it. Buy a new valve ahead of time so you don't have to take it apart again. Then try the system. If it works but still not well, then get ready to test the other vacuum pods: Trunk, gas cap, center dash (HVAC). The center dash pod is fairly common and a bit difficult to reach (I would go through the center dash' vent with one hand, and the removed glovebox with the other) to replace the center. Check the web for the detail on that one because it requires taking the pod apart while its still attached to its bracket under the dash) Not fun, but better than removing the entire dash. In the end, troublshooting - specially without a vacuum pump (you can get a hand held one from an autostore) - is tedious and is by trial and error and replacing the pods. But, either you do it, or be charged $75/hr and no gaurantee the leak can be found. New door valve is about $20 and the dash pod $25.
Feb 17, 2010 | 1983 Mercedes-Benz 300-Class
I have a sandisk sansa e260 and it keeps saying key locked system is shutdown how do i unlock it
On the top of the sansa, there is a piece that slides back and forth. slide it so that you don't see orange. If you see the orange, that means that it is locked and it can't do anything.
Jul 10, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260, key locked
jeff,
I'm not familiar with SANSA but try this.
try to locate any slide switch from your MP3 player indicating
"HOLD" or a picture of a "lock" or a "key" then switch it backwards.
and in some cases this switch can also be locate at the headset unit if the headset does have a control buttons on it
cheer,
mark
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Error in sandisk e260 mp3 player
Your player is locked - there is a lock switch on the sign that needs to be disengaged.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 MP3 Player cannot be unlocked
Reset the player first, then retry the lock slider.
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
When I try to power the system up, I receive an error message stating...Key Lock System shutdown. Please help
The hold switch at the top of the system needs to be clicked away from the ear phone jack. There should be no orange color visable.
Feb 15, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260
take it off hold then.
p.s. the hold button is on the left of the sound port
Oct 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
