Question about Fisher and Paykel Dryers
I would like to see an exploded diagram of a clothes dryer bearing assembly part number 479317
2 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
I took apart my Ge dryer to put 3 in 1 oil on bearing now I can't get the front to lock back in place
Hello;
My name is peter. I am a retired field service appliance technician.
First, you do not lubricated bearing in a clothes dryer. These are designed non lubricated bearings. When you lubricate the bearings they becomes seized up with lint and then you have real problems.
You have not provided any information on your model. So I can not instruct you.
Your model number is on a metal tag on the face or top of the door when you open the door.
Go into the following web site and put in your model number. You will have a diagram of your unit.
Water Filters Lawn Garden Appliance Parts
Mar 09, 2015 | GE Dryers
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Dryer leaves black marks on clothes
Front bearing assembly or just the slides. Easy check is open the door reach in and push up in the front if the drum has play replace bearing assembly or maybe just get away with the slides if it hasn't eaten in to far. To replace watch the video at www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | GE Dryers
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
How to install moisture sensor bar on Maytag Neptune
I do not recognize that part number but an exploded diagram for the dry is at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833
Click on the tumbler diagram.
Mar 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Fisher and Paykel Dryer ED56 Noise
your rear bearubg is mnost likely failed. and the back plaer is now hitting against the drum.
Part number (Fisher & Paykel Dryer Rear Drum Bearing Kit Part 479317)
you can replace this eazily by yourself.
check that the belt is over both rollers as well.. sometimes they slip off one of them.. especailly if moved around.
but this rear bearing is very bad. If you can find a skateboard bearing. it will fit nicely too. a much cheaper replacement and works fine. must get a good quility one lol (but any flate bearing is fine if you can find some in your workshop or neighbours lol
Jun 03, 2008 | Dryers
Open Questions:
Dryers Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
