Question about Electrical Supplies
I'm puting in two new lights and a switch the power comes in at the last light so it goes power-light-light-switch How do I wire it
  • 2,510 Answers
The power must first go to the switch, otherwise you lights will always be live and dangerous. Your Neutral (USA white) wire goes from the house supply to one light and to the other light. The live wire (USA black) goes ti the switch and then one wire from the switch will go to the one light and another wire will go to the other light. The way you laid out above will put your lights in series and your bulbs will only glow at half voltage each. I hope this makes sense and in this configuration both bulbs will come on at the same time and same brightness. If you do not understand anything, feel free to come back to me. This wiring is for US wire colour codes. For most other countries the colours would be black = brown and white = blue.
Posted on Apr 05, 2011
Connecting lighting correctly
Don't know what you're working with.
AC household electricity?
Common (White) wire goes to all three lights. Goes to silver colored screw.
Hot (Black) wire goes to switch, then all three lights.
ALWAYS put the switch in the hot wire. Not the Common.
Reason?
Let's say you are changing a light bulb.
Your feet are on the floor. You are then considered to be Grounded.
You have the light switch off. You go to remove the light bulb, slip, and a finger goes in the socket.
Result?
You get shocked.
Hot (Black) wire has the switch. This time of you slip, and a finger goes in the light bulb socket; you won't be shocked.
The power is turned off at the switch.
Common wire comes from source. (Service Panel/'Breaker Box'), and goes to the lights.
Hot (Black) wire comes from source, and goes to light switch.
Then to the first light, second light, and third light.
Is there a 3-way switch involved?
Walk in one end of the room, turn the light on, walk to the other end of the room, and turn it off?
Post back in a Comment as to the exact query.
Regards,
joecoolvette
Jan 26, 2013 | Computers & Internet
How do I wire a 4 way switch in my home
in order to wire a 4 way switch, there needs to be a total of 3 switches working to operate a device/light. you need a 2-wire coming from power source, 3-wire from first switch to 4-way switch then 3-wire to last switch. white wires (neutral) get connected together. Depending on the layout of the switches. i.e where the power comes from and where the switch leg goes to but a basic 4 -way switch is in between 2 other 3-way switches.
Jan 08, 2013 | Leviton Decora Gray Rocker 4-Way AC Quiet...
I am replacing the single toggle light switch in the bedroom entry (formerly connected to wall outlet) and have a new dual toggle or tandem switch I need one switch to power the ceiling fabn and the...
Joan, In the box where you are placing the switch, you should have three pairs of wires. Each pair should have a black wire and a white wire (plus each pair should have a bare ground wire). One pair of wires goes out to the bedroom entry. Another pair goes out to the closet light. The third pair should be coming from your electric panel and provides the power - this is the hot pair. First determine which pair is the hot pair. If you don't have a meter or tester, you can temporarily connect each pair in turn to a lamp and turn on the power. Repeat until you find the pair coming from the panel. Turn off the power. Now take note of the four screws on the switch. Two of the screws on one side may have a small metal bar connecting the two screws together. With the power off, connect the black hot wire to one of these two screws. If there is no metal bar you will have to use a short jumper wire between two screws on one side of the switch to connect them together. Connect one other black wire to either screw on the other side of the switch. Connect the last black wire to the last screw. (There is also probably a green screw by itself. Connect one of the ground wires to this, and wrap the other two ground wires tightly around the ground wire you connected to the green screw.) Now connect all three white wires together (not to the switch) with a wire nut. Install the switch in the box and turn on the power. Please vote if you found this helpful. Good luck, and be safe, Al K
Feb 22, 2011 | Pass & Seymour #690WGCC6 15A White 2SP UL...
Okay, I have the same problem... It is a cooper combination switch. There are two black wires that are coming out of the back . the instructions don't mention them at all. I am installing a new outlet...
Ok you have GFCI combination switch-plug.
Wires coming out of back of device are connected to "Load" wires.
Load are the black and white wires that go to fan, light, motor.
The black and white wires coming from circuit breaker connect to terminals marked "Line"
Look at back of device for markings.
Black wire from breaker goes to brass screw, white wire goes to silver screw.
There is one more set of screws on device. Device usually arrives with tape over these two screws.
This is what those screws are for: If you are working in a junction box, then three cables enter box.
One cable is for Line wires from breaker box.
Second cable goes to Load (light-fan-motor) that is controlled by switch.
Third cable goes forward to another switch or outlet >> and those wires connect to last set of screws on combo device. Black to brass and white to silver.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Cooper Industries Cooper Wiring 274W...
I have a new combination switch ; I want to control two lamps from one switch i connected the main lines the white one from brass upper and the other from black screw and went I turn on the switch the...
The white wires from the two light fixtures get connected to the white wire from your power supply.
Then the black from your power supply goes to the gold colored screw on the switch. Lastly, the two black wires going to your light fixtures get twisted together with a third jumper wire. The other end of the jumper goes on the silver screw on the new switch.
Dec 21, 2010 | Leviton 15a 120v Sp Switch
I have a combination single pole switch. Light switch and receptacle. In have running in the old box 2 white, 2 black and a ground. How do I install the new switch to have power to the light switch and...
You are replacing old switch-receptacle device.
New device also has switch and receptacle.
You want switch to control light, but not receptacle.
You want receptacle 'hot' all the time.
You have 2 cables that enter box.
Each cable has white, black and ground wires.
Ground wires are twisted together and attached to green ground screws and not discussed more.
Screws on new device:
Side 1 of device: New device has dark screw(s) or brass screws on one side ... these screws are connected together by brass plate. This side is the Hot side of device.
Side 2 of device: Other side has 2 separate and unconnected screws. These screws are not connected in any way. Each of the 2 disconnected screws sits opposite the switch and opposite the plug.
Cables.
One cable comes from breaker box. This cable has a Hot and Neutral wire. The Hot is black. Neutral is white.
The other cable goes to Load (light). Black supplies power to Load (light), and white connects to Neutral.
If you are uncertain which is which, testing is shown below.
Connect the device:
Side 1 of device: Black Hot goes to dark colored screw(s) that are connected by brass plate. (This is only wire connected to this side of device)
Side 2 of device: Black that goes to Load (light) connects to screw that sits opposite the switch.
Side 2 of device: White Neutral connects to screw that sits opposite the plug
One wire is left .. the white from light. This white wire connects to white Neutral wire. Since white neutral is already connected to device, look on back of device to see if there is a quick-connect hole for you to shove wire into back of device. If device doesn't have quick-connect, then twist white wires together, and add a short jumper wire to device, and then all the whites are connected to neutral. Circuit is complete.
How to test for Hot and Neutral
Separate wires.
Turn on power.
Test each wire to bare ground.
Tester lights up on hot wire.
Now test hot wire to other wires.
Tester lights up on neutral
Nov 17, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have a 1595-SWTTRWCC4 switch. None of the wiring diagrams show the two black wires coming from the switch. I am using the switch to turn on a light above the sink and use the outlet for counter top...
If the wires are coming out of the switch portion & not the outlet, 1 goes to power the other goes to that color wire that goes to your light. All you are doing with a switch is cutting one side of your power, putting switch in completes the circuit when it is turned on. Or breaks the circuit when it is turned off. The other wires, power in & back to light get wire nutted together.
Sep 04, 2010 | Pass & Seymour #TM818WCC6 15A White...
Wiring comination 2 switch, with exisiting light to new bath fan
Please note that there are many ways to wire this device.
In general, this is how the Pass and Seymour Legrand 1595-2SWT device is usually wired:
There are 3 wires permanently attached to the device, black, red, and yellow. These wires are for switching _only_ and are in no way connected to the GFCI receptacle at the factory. The black is "common", which means that this is the wire that is connected to the incoming HOT (black) wire _from_ the circuit breaker (or source). When making this connection add an approx. 6 inch black pigtail to it. (more on this later.)
The red is connected to the black wire (switch leg) that goes to, pick one, let's say the existing lights. The yellow is then connected to the black wire (switch leg) that goes to the new exhaust fan.
The incoming white (neutral) wire that is in the same cable as the incoming HOT wire is connected to BOTH the white wire that goes to the existing light and the white wire that goes to the new exhaust fan. Again, when making this connection, add a 6 inch white pigtail to it.
The switches will now work.
Do you now see that to power up the GFCI receptacle all one needs to do is connect the (see above) 6 inch black pigtailed wire to the "HOT" (LINE) screw terminal and the 6 inch white pigtailed wire to the "WHITE" (LINE) screw terminal?
In this case the lower LOAD screw terminals on the device are _not_ used.
Mar 29, 2010 | Pass & Seymour / Legrand 1595-2SWT...
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
How to wire combo switch
you should have 4 wires total (not including grounds, which get twisted together and connected to green screw) you have to know which is the power lead, and which goes to the light! 2 blacks, and 2 whites ...the 2 whites go together and connects to the silver screw, and the 1 black power lead goes to the gold screw, the other black wire(to the light) goes on the opposite side of switch above the silver screws on another gold screw
Apr 06, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
Electrical Supplies Logo
432 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
