My Acer 5720 all of a sudden shut down (power out). Everything else plugged in the house works fine. I hit the on/off button and all I got was a cursor at the top left corner of the screen. I waited a while got myself a drink. I hit the on/ff button again and it started up no problem
  • 17,130 Answers
Seems that the power outage had reset the PC because there was not back up and so a restart solved the issue as the OS had hung up.
make sure that the back up is good at such times so that hard disc is protected.
Posted on Apr 05, 2011
    Novelist:
  • 151 Answers
Possibly an overheat problem. If you use the laptop on your legs, table cloth, sofa, carpet etc. it can block the air vents in the bottom of the laptop causing it to get hot. If it has never done this before, it could be an indication that there is fluff, hair (cat or dog) or other assorted lint blocking the internal air passages thru the processor heatsink or other parts. This is caused by using the laptop on fabric surfaces (especially floors) - it sucks - up lint and over time it accumulates causing overheat problems. This is easily cured by firing pressurized air into the vents (can of air or from a compressor), in short bursts, to dislodge the dust, then use a household vac to clear the vents.
This should prevent this problem.
Acer aspire 5720, after erasing everything, still getting "low disk space" message. beyond disc cleans & system defragmenting...Any suggestions?
Hi Brandon, You can try cleaning the temp files Click Start >> Run, then type %temp% Enter, then delete everything in that folder.
Please download CCleaner to clean up your registry
CCleaner Download
Mar 11, 2014 | Lifetime Acer Aspire 5720-4126 Replacement...
Just got an acer Z3751 that the screen suddenly shuts downs but the power button is still is on , and am un able to restart or resume my work by pressing any buttons.. i went to the power options and i...
This model has mother board problems. In addition to sudden auto switch off, it also has problems in starting the system. what Acer workshop can do for you is to change a new mother board. After changing mother board, the problem comes back after some time. So my advice is change a new PC. of course not Acer again.
Mar 01, 2012 | Acer Aspire Z3751 All In One PC Desktop
My acer aspire laptop has a blank screen when it is turned on it was working fine and I pressed alt+f10 then it went blank with just a white blinking cursor
Hold down the power button until the computer completely shuts off, wait 10 seconds, power it back on.
What happens?
Nov 21, 2009 | Acer Aspire 5720 Notebook
Acer Laptop runs but shuts off suddenly
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Aug 03, 2009 | Acer Aspire 5720-6661 Notebook PC
Turns off shortly after turning on
Is this when connected to power source or on battery?
If it is on battery the battery may need to have its memory refreshed.
Turn the 5720 off, remove the battery, hold the on/off button down for 15 seconds and when done put it back together and turn it on.
Good Luck
Apr 22, 2009 | Acer Aspire 5720-6661 Notebook PC
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Laptop
Unclear here? When you take the battery out, it shuts off? Assuming you do have the power supply plugged in? (sorry, I know it sounds silly that I ask that, but you just never know)
Acers will work with the battery out, actually that is how I HAD to work my acer. I personally would not buy another ACER because of the problems I have had with mine. I had to remove my battery as the keyboard and mouse would NOT function with the battery in place. (the battery never held long charge from new anyway). So I started using it plugged in all the time. (no battery).
As far as the hitting the wireless button and the computer shuts down, I'm wondering if just moving the laptop period is what is causing the shutdown. My Acer too, (because of jiggly PS jack on the back) would cut off is laptop is even slightly moved. Maybe while pushing the button the laptop too gets moved? Unsure. It may be a shortage issue, but I suspect it has more to do with shorted PS jack.
Hope this helps at least some. Good luck!
Aug 19, 2008 | Acer Aspire 5100-5022 Notebook
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
