Question about Eton E1 XM-Ready AM/FM Radio Satellite
Help please - my E1 has had new chip fitted to sort the display problems and that seems fine now (at extra cost!) my problem is the sticky rubberized finish is starting to break up and looks and feels horrible. Is there any way I can remove this finish?
I just spent almost 3 hours removing the horrible sticky coating on the E1 case. It was getting so sticky I didn't even want to turn the radio on. I bought a small bottle of rubbing alcohol and went to work. Rub and rub a panel at a time, and finally the radio is a pleasure to handle. You can rub over the white lettering and will not damage the letters or logos. I even rubbed the speaker grille which also was very sticky. There are still a few small sticky hard-to-reach places next to the bass and treble knobs but I plan to attack them with a Q-tip. Overall this was worth the time spent.
Posted on Aug 12, 2012
One owner on eham.com remarked that he soaked the cabinet in rubbing alcohol, after opening the unit and removing the pc boards. Whatever chemical is effective I believe the lettering would be destroyed.
Posted on Apr 15, 2011
I broke a needle and it ended up under the bobbin
I would do everything possible to get the broken piece out now, as opposed to having bigger problems later. Get a fine pair of tweezers, a magnet of some sort that might fit into the area and try to dislodge the broken piece. If you can not find a magnet that would fit, perhaps working with the tweezers and a Q Tip might help you to remove it, or even a Q Tip with the cotton removed and a sticky material on the end like gum or even a small amount of toothpaste. What ever you use, you should try and remove it now.
Jul 28, 2010 | Elna Quilter's Dream 6003Q
Water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Jan 05, 2010 | Culligan Sediment Water Filter
Kyocera Mita FS-1000+ paper slip single page? 5 pages print ok
This is a known problem.
Kyocera pretends to produce very silent printers. Therefore certain sheet metal parts inside the printer have a small piece of sponge rubber at their endings.
Unfortunately over the years this sponge rubber gets sticky. The corresponding lever, that is covered at its end with sponge rubber, sticks too long to its initial position. This is the reason why a certain lever is moved too late by the electromagnet into the position where a certain pulley is released.
As a result printing and paper movement are no longer coordinated and the printout is too low on the sheet.
Solution: Get rid of the sponge rubber, clean the lever very well in order to avoid it from sticking in its initial position. As a result you will here a much harder metallic noise when the lever moves, but the printout should be o.k.
Apr 07, 2009 | Kyocera Mita FS 1000+N Laser Printer
Came home from trip tp find oven display flashing E1-F1- Oven will not turn on and cannot clear display! Even tried turning breaker off and back on!!Please Help
the e1 f1 failure means an internal control failure. which means you will need to replace the control board.
usuallly it will cost about 125-150 bucks.
Feb 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon 8170 8180 printer prepare new drum message
you have to paste a piece of paper on the sensors that looks like 2 blocks (i used the sticky side of a post it note). that will fool the printer and get rid of the prompt
Sep 21, 2007 | Office Equipment & Supplies
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
My Golden Motorola RAZR D&G always displays no service !!!!
I have the same problem, displays shows no service and occasionally says invalid battery. Done all the usual things i.e. tried different sim card, different battery. I bought the phone on ebay from Hong Kong. At the moment it is a very good ornament! Help please.
Sep 06, 2006 | Motorola Mobility RAZR V3
Eton E1 XM-Ready AM/FM Radio Satellite Logo
752 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
