Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer modelgune
  • GE Master
  • 17,130 Answers
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Posted on Apr 05, 2011
  • 132 Answers
The problem is with the auto defrost cycleThe culprit could be the defrost heater, defrost timer, defrost termination or the fusible link. You will need a technician to help you solve this problem on site.
John Lewis Fridge Freezer - Freezer compartment is working, fridge light works, but the fridge is not working. Please help!
Leaving the freezer door open for extended period of time could have caused the evaporator to freeze up and prevent cold air being driven into refrig compartment. Unplugging it for 24 hours will give it a great chance to unfreeze. You can also check the freezer temps before you do this - bet they are no where close to the ideal of zero degrees since the ice buildup is an insulator and prevents the freezer compartment from going down to the correct temps. And if the freezer is not at least 10 degrees or less your ice maker, if you have one, will not work since it has a thermostat that only cycles the ice maker at 10 degrees or less.
Jul 23, 2016 | Frost Refrigerators
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
MY MAGIC CHEF IWORKS FINE 2 TO 3 WEEKS A TIME ,AFTER 3 WEEKS IT STOPS COOLING - I REMOVE EVERYTHING OUT FRIDGE AND UNPLUG IT FOR A DAY ,A DAY LATER I PLUG BACK AND IT OPERATES FINE FOR ABOUT 3 WEEKS AND I...
Hi and welcome to FixYa, I am Kelly
Without your model number here is what most likely has happened:
The automatic defrosting system is not working due to a component failure.
The components of the automatic defrost system are:
1. Defrost control
2. Defrost heater
3. Defrost thermostat.
4. Wiring to inter-connect 1 - 3 above.
What your currently doing is a manual defrost cycle every 3 weeks because ice blocks the air-flow across the evaporator in the freezer compartment so everything starts warming up in the fresh food section first and finally the freezer as the ice block gets larger.
FYI you can unplug it... remove the contents from the freezer...use an external directed into the freezer compartment for just over 2 hours to do the same process your doing in 24 hours. Until the automatic defrost system is repaired you should do a manual defrost at least every 4 days.
Most units are on an automatic defrost cycle of 6 - 8 hours (usually) all the way up to 10.35 hours per cycle. Yours just is not working at all.
Thanks for choosing FixYa,
Kelly
Kelly
Aug 15, 2011 | Refrigerators
The freezer has quit freezing. The refrigerator
your refrigerator 100% depends on the freezer (unless you have a sub-zero brand fridge, that has 2 compressors). So your fridge will be warm soon too. There is no fuse in the fridge. Try unplugging it for 24 hours and see if that helps, otherwise it's better to call for service.
Refrigerator repair orange county, ca
Feb 06, 2010 | Refrigerators
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
693 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
