Question about EnGenius EOC-3220 (EOC3220)
I am trying to open my enginus wireless configuration by enetring username and password as admin by it is not accepting it. It might have been changed. what to do.
What about after you try and it displays a smiley face or other times none. what to do then?
Posted on Sep 29, 2012
    Problem Solver:
  • 14 Answers
If the password has changed then the only option is to set it back to factory default settings to use the default username and password, here is the steps to take to do so. An RS-232 null modem serial cable is required for this procedure
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
d. unplug the power on the POE injector wait 5 seconds and plug it back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Hope this gets you in the right direction.
Posted on Apr 05, 2011
Wats the password wifi to 2wire657
You can access the wifi password through your router configuration page.If you are not aware to open you router configuration page, Follow this.
1. Open command prompt2. Type ipconfig and press enter3.You would have a list of information in which you can find the default gateway in the adapter list.4. This is your router's IP address5.Type the ip address in your browser and hit enter (For example : http://192.168.2.1)6.You would be directed to router's configuration page.7. Login to access ur router's configuration8. Go to wireless security options where you can reset or have your wifi password
P.s : If you do not remember your username and password for configuration login, Try for default ones such as Admin/Admin or Admin/*Blank*.Else You can refer to your router's manual for configuration username and password.
Apr 07, 2012 | Computers & Internet
I try put in web browser 19216811 i put the user and password but do not work What i do for show the configuration to router
Open a web browser. Type 192.168.1.1 in the address bar. Username is admin Password is admin
Unless you changed your password to the router, in which case you will have to do a hard reset on the router to get all the defaults back. This means, more than likely you will have to setup anything that you had configured on the router before the reset.
Apr 13, 2011 | TP-LINK TPLink TDW8950ND 150Mbps Wireless...
Where can i find my configuration web page?
Open your browser and enter the Linksys configuration URL.
http://182.168.1.1
The default login = admin
the default PW = admin
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 08, 2011 | Linksys Wireless-G WRT54G Router
I want to change my password lynksys wrt150n.
Are you speaking about the wireless network password?
For this you will need to access the setup page of the router?
Connect the computer to the router with the Ethernet cable.
open the setup page of the router.
Go to wireless tab and change the wireless settings.
If you want to change the ' Router ' password then go to administration tab and change the router password.
Click Here for more information about the routers and network
Oct 19, 2010 | Linksys Wireless-N WRT150N Router
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
Need to find existing WEP ID, do not want to reset my WEP ID
Flip over your ACTIONTEC and you would see there the default wep key. If you've had it personalized before, you have to open the configuration page of your modem and check for the wep key.
To go to the configuration page, open your internet explorer and type in 192.168.1.1 on the address bar. that is the default address for your actiontec. type in your username and password when prompted. the usual default it ADMIN for username and PASSWORD (lowercase) for password. or you could also try ADMIN (uname)-ADMIN(pword).
click on the wireless settings icon and then click on basic security settings. scroll down on the middle of the page and you will see there your wep key.
if you are unable to open the configuration page because you forgot your username and password, you can reset your modem so that it the uname and password will go back to its factory default settings (admin/password). However, if you are using pppoe connection (authentication using username and password to connect to network) you can lose your connection and you would have to configure your router. so be careful not to press the reset button at the back.
Apr 19, 2009 | Actiontec (5GE583000-01) Router
Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Apr 13, 2009 | Computers & Internet
The default username and password to configure router doesnt work
Try to turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin. Also turn off any firewall you have.
Apr 01, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
How to start wireless services of dna a211-1 modem .
If it has wireless then its probably on, you just have to configure it.
you can access the configuration page, by opening internet explorer and typing in the address bar 192.168.1.1
it will ask for a username and a password try admin as the username, and for the password try "admin" or "password".
you should be able to configure wireless from the page that opens up.
next you need to configure wireless on your computer, which can be done by:
  1. click on start
  2. click on run
  3. type ncpa.cpl
  4. right-click wireless local area connection
  5. click on view available wireless networks
  6. and connect to your network
Feb 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys Wireless Router Model No. WRTU54G-TM Router Configuration
Open a browser
type 192.168.1.1 in hte address line, press enter
you should get a prompt for a username/password
Leave username blank
Password admin
this should get you to the firmware configuration.
If you can't access the router, press and hold the reset button on the back for 5 seconds with the point of a pen, then try again.
Jun 04, 2008 | Computers & Internet
EnGenius EOC-3220 (EOC3220) Logo
336 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
