SOURCE: Phone Memory Full
Dear Rohan_anand,
Actually the problem is because your SMS/MMS inbox is full.
Over the last six months you have piled plenty of messages in your inbox that you didnt delete. or you may have MP3's shared via bluetooth in your inbox.
Try saving them to you memory card and delete them from your inbox.
You will not receive this message anymore.
Let me know, if this doesnt solve your problem. Please leave a comment here as i will be checking it time to time.
Would appreciate if you can rate this solution if it solves your problem.
Best Regards,
Techno-geek.
SOURCE: memory full
Press *, 3, Green Button and Power button simultaneously, it works 100%.
Please vote me if it works.
But dont forget to take back up of data like contacts, notes, birthdays.
You press this buttons until it asks for country and time
SOURCE: cannot use the nokia pc suite on nokia n 73 it
This is a common problem with this nokia. The actual phone memory (not the memory card) is full. Go to menue and then OPTIONS. Select MEMORY DETAILS and select the Phone Memory. If the phone has low memory, then try deleting some contents like Text, MMS, Emails..... and see if that helps. Also you can try doing a *#7780# to do a Reset if deleting the text and MMS did not work. It will reset your phone but does not delete your data
SOURCE: hi.. My nokia N73 is always showing as phone memor...
try ( * + '3' + 'call button') hold this three keys and power up ur mobile without simcard dont leave the button untill u get the countries name for further details.be sure to save or backup data saved in your phone and memory card. this format will remove each and every file saved in your phone memory or memory card which cannot be restored if deleted once..
