Question about IBM Computers & Internet
I try to format my system but it will display NTRL is missing. In the system setup the cd/dvd drive is disable, if i enable it and try to run the system again, it will be in disable mode. Is the problem from the motherboard?
  • IBM Master
  • 27,725 Answers
First check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 05, 2011
My laptop getting slow and slow.. how do i reformat my computer??
Just get an Operating System CD/DVD, you want to format with, place it in your CD/DVD drive and make a computer reboot. When the computer will restart, during the pre-booting process, it will show "Press any key to boot from CD/DVD". Now press any key to start the formatting process (But before that, be sure, you have CD/DVD boot option ON in the BIOS settings).
Now follow the on-screen instructions. That's all.
For more details how to format Windows 7 from CD/DVD, read this section: http://howtoformatacomputer.com/format-windows-7
If you are willing to format Windows 7 from USB Drives, you may want to read this section: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
NOTE: If booting from CD/DVD is disabled in your BIOS and you don't know how to enable it, please let us know by commenting over this reply.
Hope this helps, Mrityunjay
Jun 19, 2012 | Samsung N150 (36725723009) Netbook
Today when i was installing windows 7 and the setup was just started i found an error- 'cd/dvd driver missing'... i have already format the c drive so System can not even boot up... please help me...
Reseat the CD/DVD drive. Reboot and go into the BIOS setting to see if the CD/DVD drive is detected.
If not then the CD/DVD drive is faulty and needs to be replaced.
Jan 22, 2012 | Samsung Computers & Internet
I have a ACER Aspire 5520 Laptop , My DVD Drive doesn't display in windows or in BIOS. The drive works fine in other computers....I tried swapping it with a working drive and it still doesn't show up! Any...
It's most likely the nvidia graphics chip. Bad connection caused by getting really hot and cooling over and over. Many times this issue manifests itself with actual video related issues or no post. Other times though, things like wireless and detection of the optical drive. Nvidia chip needs to be reflowed. Do it (or get it done) right or it won't be long before it happens again. Also, replace that heat pad on that chip with a copper (or least aluminum) shim with some artic silver. Assure good contact and keep your cooling policy set to active on battery and ac. This is probably beyond the scope of most, but if you're skilled enough to remove the motherboard yourself you may be able to find someone who can do it for you. And you'll probably save at least 50% on labor since they don't have to do the disassembly/assembly.
Jan 11, 2011 | Acer (99.B0311.002) Internal 50x CD-ROM...
How do I enable the drives on my Gateway 505GR?
Enter BIOS SETUP.
Change the "boot order" to put the CD/DVD drive as the _first_ boot-device.
Save/Exit, insert the CD-ROM containing the Operating System, and your computer should boot from the files on the CD-ROM.
Apr 08, 2010 | Gateway 505GR PC Desktop
Error 233 is appearing when I start up my machine followed by system freezing
Hello,check the drive properties. Simply right click on My Computer and select Properties. Go to Hardware->Device Manager then double-click on your virtual drive to open a new window and point to properties on it. Check in the bottom for a check box "Enable digital CD audio for this CD-rom device" and try to enable it or disable it.
Jan 20, 2010 | Computers & Internet
Targus CD/DVD does not show in directory
try to use another usb cable for your external dvd drive>>>> then if it's not working again try to check the bios setup if the optical drive is enable. if the setting is disable please change it to enable>>> if still not work back on where did you bought it>>> maybe it is defective...
Dec 14, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
DVD doesn't open
This problem may be a bad cd/dvd drive. When the computer boots up, go into the BIOS setup. Check to see if the computer recognizes the drive, and make sure it is not disabled. Next, check in the "device manager" to see if there are any yellow question marks or red X's. This might indicate a driver problem, or a misconfigured drive. If these steps fail to resolve your problem, replacing the drive would be your next step. This is a fairly easy task, and worth the time to research the steps for your particular model.
Nov 15, 2008 | Gateway MT3705 Notebook
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
