Question about Nokia E51 Cellular Phone
When phone is switched on the following is displayed- Continue using phone in offline mode? All controls are frozen and pressing of any buttons has no effect.The only button working is the on/off button but the phone does turn on when the charger is plugged in and is charging the battery. Is this a terminal problem or is there a fix available?
  • Nokia Master
  • 17,130 Answers
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Apr 05, 2011
My phone is in offline mode,when i insert a sim card it ask whether i want to continue in offline mode but when i choose no, it tells me to insert sim
when you insert your sim card and press ok when it ask you whether you would like to continue in offline mode . once your phone starts go to the settings option and click the master reset or restore factory setting. once restored swtich off your phine without removing the sim card and then switch it on after 5 mins . it should solve your problem
Oct 19, 2013 | Cell Phones
My nokia c5 is in offline mode how am i going to openline it?
on standby mode. Press the power button once, you should see some options. Just pick a different profile and answer yes to the next question or open the phone, adjust your sim and restart your phone and it will ask to continue using phone in offline mode and you click no
Jul 09, 2013 | Nokia C5 Cell Phone
How to remove offline mode in nokia e72 mobile
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Feb 26, 2011 | Nokia E72 Smartphone
My NokiaN70 is in the offline mode and I cant get to be in the online mode. On start up it asks continue using the phone in offline mode, when I press the No button it does not respond but continues to...
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center.
Good luck
Visit Again...........Fixya.com
Aug 15, 2010 | Nokia N70 Cellular Phone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
It says continue using phone in offline mode?
Error Message -
Troubleshooting tried -
Tried with Samsung service centers but no gain.
Master reset, Software reinstall, also tried to reset imei number.
Most of the troubleshooting was done by certified techs, if you could help to fix
this issue, you must be called as the best Genius of Technology!! Please Help.
Dec 26, 2009 | Cell Phones
Nokia N95 8G - freezes when you turn it on and you can't go past the NOKIA welcome screen. Tried taking the battery out, charging it, etc.
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 29, 2009 | Nokia N95 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
ORIGINAL SETTING
Hi Jun,
see below....
Changing the Display Language
To change the language that is displayed on the control panel,
take the following steps:
1 In ready mode, press the Menu button ( ) on the control
panel until you see “Setup” on the bottom line of the
display.
2 Press the Enter button ( ) to access the menu.
3 Press the Enter button ( ) when “LCD Language” displays
on the bottom line of the display.
4 Press the scroll button ( or ) until the language you
want to use is displayed.
5 Press the Enter button ( ) to save the selection.
6 Press the On Line/Continue button ( ) to return to
ready mode.
Aug 08, 2008 | Samsung CLP-510 Laser Printer
Nokia E51 Cellular Phone Logo
152 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
