Aspire 3935: Touchpad for wlan/bluetooth and backup manager is constantly flashing, even when I am not touching it. I understand that many have the same problem
    Novelist:
  • 100 Answers
Hi this is not a problem ur laptop has a bluetooth service in it which is blinking when u turn on ur laptop its just viewing a message whether ur bluetooth is off or on and for backup manager its asking to backup ur files so that u don't lose any important data if ur system crashes just don't worry it happens on all laptops
was this helpful pls rate my solution if u liked it
with warm regards-bonefirediv
Posted on Apr 05, 2011
My Acer laptop keeps restarting randomly whenever i use it.
Most likely cause would be overheating due to clogged fan intake/exhaust or failing fan. If you want to tackle yourself Google "disassemble Acer ______ laptop" (insers your model number). You can determine if overheating is likely by carefully blowing some canned air into the fan intake.
Mar 13, 2016 | Acer Aspire 3935-6504 Notebook
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Hi, am using Acer Aspire 3935. The Acer Backup dialog box always pop out, even I click cancel, still keep poping out, ...
It is most likely popping up because it's recommending that you do a backup, if you use the program but simply don't want it to constantly be popping up, you should be able to find the program in the list of programs in your start menu, and from there there should be an option to turn off reminders/notifications.
If you do not use the program and simply want to get rid of it, if you click start, control panel, then 'programs and features' or 'add/remove programs' depending on your version of windows, you should find a list of all the programs installed on your computer, simply find the backup program and click uninstall.
hope this was helpful.
May 30, 2011 | Computers & Internet
No wireless network adapter found after format acer aspire 3610 and the same problem in the bluetooth
you can download the WLAN adapter here
and the bluetooth adapter here
Your machine may have internet conectivity issues without the WLAN Drivers. So you may need to download these drivers to a USB flash drive. Then transfer them to your acer.
Dec 03, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
My laptops' unit is Acer Aspire 3935. The button wifi/bluetooth/acer backup manager/ button blinks even if did not hit it. what's wrong with my laptop?
this lights blinks all the time (its searching for connection even when you are not)......your laptop is just fine
May 12, 2010 | Acer Aspire 3935-6504 Notebook
My Acer 5732Z running under windows 7 has a keyboard & mouse prob
First thing to try to uinstall and reinstall the software for your touchpad. Go to Acer and get the latest drivers and or software. Sometimes, just removing the driver and letting windows find it again in device manager is enough to fix it. hopes this helps.
Normally though. keyboard and touchpad are seperate entities. which made me think of the motherboard as that is the only constant between the 2 but, if your touchpad is buggy maybe it is causing issues elsewhere.
Mar 11, 2010 | Acer Aspire 3000 Notebook
i also have the same problem with you, try to disable the" launch manager",,
Jan 17, 2010 | Acer Aspire 3935-6504 Notebook
Activate Bluetooth on Acer Aspire 6530
Dear craigpawlak,
I think the problem you are facing is an issue with drivers.
to ensure this is a problem as I mentioned, follow the following steps:
  • - Click the start button
  • - Right click on My Computer
  • - And click properties >> click the Hardware tab
  • - Click device manager
There you will see the drivers installed for your PC and see if any hardware list is accompanied by a question mark that's the hardware driver is not installed.
Solution to the problem is to install drivers Bluethoot, you may get in the cd when you bought it. if you do not have it, then I'll give the link to get these drivers. (available for Vista and XP). Click here to download driver
How To Install Driver ?
  • extract the drivers you have downloaded from the link I have given or cd drivers and double-click setup.exe
  • just follow the instructions to complete.
  • restart your notebook.
  • now you can try again to activate bluethoot
Do not hesitate to contact me if there is a problem or my explanation is less understandable.
regards.
Jan 06, 2010 | Acer Aspire 6530-5143 Notebook PC
The tuch pad is not working plz help
I recommend you to uninstall and reinstall the touchpad drivers from Device Manager.
Press Windows Key and R key.
Type devmgmt.msc and click on OK.
In the Device Manager expand Mouse and other pointing devices.
Right click on touchpad and select Uninstall.
Right click on the touchpad now and select scan for hardware changes.
You can even try to reinstall the new touchpad drivers for your notebook model from acer support website.
For Rundll has stopped working, follow the steps in the below weblink:
http://www.registryrepairsolutions.com/rundll32-has-stopped-working.html
Jul 07, 2009 | Acer Aspire 6920 Notebook PC
Divers problem
Here bluetooth:Bluetooth Broadcom
Acer Aspire 493X Windows XP Driver
(Download)
You need Winrar to extract it
Here all drivers, they should work as well on 4930:
Acer Aspire 4935 4935G Windows XP Drivers :
Chipset Intel
(Download)
Modem Conexant
(Download)
Webcam Suyin Crystal Eye
(Download)
Webcam Bison Crystal Eye
(Download)
WLAN Atheros
(Download)
WLAN Broadcom
(Download)
WLAN Intel
(Download)
MIR ENE
(Download)
LAN Atheros AR8121/AR8113/AR8114 Gigabit/Fast Ethernet Controller
(Download)
Launch Manager
(Download)
Card Reader
(Download)
VGA Intel
(Download)
Audio Realtek
(Download)
Bluetooth Broadcom
(Download)
Touchpad ALPS & Synaptics
(Download)
VGA NVIDIA
(Download)
from Windows XP & Vista Driver
Mar 02, 2009 | Acer Aspire 4930-6862 Laptop
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
