Deep sea 601d is an engine controller with automatic cranking for generators.can you please send me a copy of electrical connection diagram of this type of controller.
4 Suggested Answers
Powerman
  • 68 Answers
SOURCE: Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: 1987 sea ray wireing diagram
black to black, white to white Etc. hope this helps
Posted on Aug 19, 2010
mabpest
  • 1152 Answers
SOURCE: I have 1990 Ford F150 with 2 gas tanks.Electric
check fuel relay under the hood..it may be blown..look in owners manual for relay location.
Posted on Feb 14, 2011
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Pontiac Montana sv6 2006 electrical or what? Volts keep jump in from 12.3 to 15 while I drive .got stuck on highway 3 times when the voltage hits below 12.1 just swapped the battery...please help
    Have your (alternator) Charging system tested ! .This is a computer controlled charging system .
    The body control module (BCM) is a class 2 device. It communicates with the powertrain control module (PCM)/engine control module (ECM) and the instrument panel cluster (IPC) for electrical power management (EPM) operation. The BCM determines the output of the generator and sends the information to the PCM/ECM for control of the generator field control circuit. It monitors the generator field duty cycle signal circuit information sent from the PCM/ECM for control of the generator. It monitors a battery current sensor, the battery positive voltage circuit, and estimated battery temperature to determine battery state-of-charge (SOC). The BCM performs idle boost and load management operations.
    Powertrain Control Module (PCM)/Engine Control Module (ECM) The PCM/ECM directly controls the generator field control circuit input to the generator. It monitors the generator's generator field duty cycle signal circuit and sends the information to the BCM. The PCM/ECM will override the BCM control of the generator when one of the following conditions is met:
    The engine cooling fans are on high speed.
    There is a high fuel demand.
    The calculated ambient air temperature is less that 0?°C (32?°F).
    Oct 21, 2015 | Pontiac Cars & Trucks
    Why genset not starting.
    you say diesel so I assume that it is a diesel engine
    The symptoms indicate low pressure in the fuel pump and that can be from air in the system or blocked filters
    you mentioned deep sea controller so is it right to say that it is on a boat
    If so then check the fuel tanks for a black moss like substance
    this causes filter blockages and eventually gets to the pump and injectors and creates hard start problems
    if so empty the tank and clean out as best you can
    regularly use diesel fuel conditioner to stop the moss regrowth
    It comes from condensation in the diesel tank and is a common problem in tanks that are left standing partly empty or with low fuel in them
    May 25, 2015 | Cars & Trucks
    I have a Kohler Marine 4ES Generator in my 29 Foot Sea Ray and the engine keeps cycling (no load) from almost shut-down to max speed. What can this be? I have changed the Electric Fuel Pump - Fuel...
    The governor and / control maybe your issue. Also if you have the electronic governor model, check the speed sensor screwed in near the fly wheel, it should have approx 2VAC on it during crank.
    Jun 19, 2013 | Kohler Electrical Supplies
    Engine surges
    Hi Johnny,
    I think the heart of your problem lies with the ethanol content in today's gas. It has at the very least 10%. The problem with gas containing ethanol, it only has a shelf life of about 30 days. What happens is the ethanol absorbs water from moisture in the air. The ethanol and water bond together and have a higher density than the petroleum based gas on top. It is exactly like oil floating on water. When this happens the octane rating of your gas drops dramatically, that's problem number one. Problem number 2, let's say your generator has a 10 gallon tank. Each gallon containing 10% ethanol, 1/10th of a gallon times 10. After about a month or two in a humid area you have a full gallon of water and ethanol sitting on the bottom of your tank. The best generator in the world will not run properly with this garbage sitting at the bottom. Problem number 3 ethanol is a strong solvent, it will deteriorate your fuel line. It will gum up the inside and make the exterior brittle. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe fuel line and replace or install an inline fuel filter.Check out the website pure-gas.org to see if ethanol free gas is available in your area. Here are two products that I strongly recommend Sea Foam and Sea Foam Deep Creep. I would completely drain the tank on your generator, install the new fuel line, spray a liberal amount of Deep Creep into the fuel line and let it sit for about an hour. Then drain the fuel bowl, fill the fuel line again with Deep Creep and let it sit for a little while. With the fuel bowl off, you should be able to lift the float and have smooth action with the float pin, no sticking the Deep Creep should flow smoothly when the float is lifted, after this is done re-assemble the carburetor and attach the fuel line to the tank. Add enough gas to run the generator for about 20 minutes and then use the Sea Foam. I have had stunning results from Sea Foam, I am not affiliated with this product it just works great and that is why I recommend it so strongly. Try to get the spray can of Sea Foam because that will be the easiest way to get it into the carburetor while it is running. Bring the generator outdoors after you have added a little gas to the tank remove the air filter from the carburetor and start the engine. Spray the Sea Foam directly into the carburetor, do not spray so much that it stalls the engine. After a spray or two you will get a feel for how much you can spray without stalling. Now the fun begins. Sea Foam removes carbon fouling from the engine and cleans the jets in the carburetor and it does this incredibly well but it produces an amazing amount of smoke, this can be very alarming at first but do not worry this is absolutely normal. You will be stunned by how much carbon gets burned out. Close the windows in your house and tell your neighbors in advance so they don't call the fire department. There will be that much smoke. Intermittently spray and let the fouling burn out. Do this about four to five times then spray a bit in the gas tank and let the generator run until it is empty. After the generator is empty add a little Sea Foam to the crank case oil, read the can for the proper amount. Store the generator empty. Sea Foam has stopped valve tapping, erratic float problems, rough idles and hard starting issues for me, It is an amazing product. I know that the desire to have a full tank in the generator for when the power goes out is very strong but it will cause you nothing but grief in the long run. You are better off finding gas cans that are air tight, they will not allow moisture to be absorbed into the ethanol and you will have a much longer shelf life. When the power comes back on I use a kerosene pump to empty my generator and then I run the engine dry.By using this method I have an extremely dependable machine that starts on the first pull every time even after sitting for over a year.Sorry for being so long winded but this is what really works and for those that also read this post who are not mechanically inclined, the long winded explanation gives them a clearer idea on how to solve this problem. Good Luck,Michael Burke
    Nov 28, 2011 | Coleman Powermate Powermate 5000W...
    Frigidaire mod.# FFU20F9GW5
    You have problem stil problem I thik its electrical you can send me copy of electric diagram to may email I can check for you and give posiable solution.
    may email is : czesiek1948@op.pl
    Nov 03, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
    Regards,
    Powerman
    Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
    Computers & Internet Logo
    David Payne
    David Payne
