Question about Microwave Ovens
How do I change the clock on lofra Loo9002 - Microwave Ovens
How do i change the light clock
if you want to change time. push clock, set the time and then push clock again thats it. Or are you changing the bulb itself.
Sep 23, 2014 | Microwave Ovens
Forgot how to set clock on Morphy Richards P90D23AL-B7/H Microwave Oven
Iain's solution is great but one addition to it which threw me completely.... if changing your clock in the afternoon.... the time isn't using a 24hr clock, it's just a 12 hour one so if you are wondering why the time still won't set try using the 12hr clock instead
Oct 30, 2011 | DeLonghi P90D23ELT2AH Microwave Oven
I dont know how to set the clock on the oven, therefore I cant start the oven
It depends on the make/model of the set.
All you need is to press and hold and the clock will blink on the hour/minutes and it must be changed and set. Use the button marked clock to press to hold for setting. Change time using the 0-9 key pads by typing the correct time..
Jul 23, 2011 | Microwave Ovens
I wish to change the time on the clock on my LUMINA MICROWAVE. I lost the manual so I don't know how to do it. Can you please give me some guidance on how to change the time? I look forward to hear...
I feel your pain, I am in the same position. After endless mucking around I finally figured it out. By the way, this is for my model P10034AP. Press these buttons: - Cancel [to abort anything currently underway] Clock [to set the time] Cancel [to clear the time allowing input] nnnn [the 4 numbers HH:MM in 24 hour time] Clock [to set the new time]
Hope that helps :) Cheers Jonathan Barton
Jun 29, 2011 | Microwave Ovens
Hi,i have a lofra max maxima oven and my stove,which i control by touch isnt responsing to me.please is there any solution?
Here is something to try:
This is from Lofra manuals
It's possible to lock the selected functions by keeping the "Key" button pressed . An acoustic
and flashing warning will activate whenever any changes to programmed function are tried to be
made. By activating this function it's possible to switch the Electronic Module off while the
function controls remain active. To deactivate the lock keep the "Key" button pressed a second
time.
If you still have your owners manual look up child lock. If you do not have a manual and the oven door is unlocked I really need a model number.
Thanks,
Kelly
Jun 20, 2011 | Microwave Ovens
Hey there, I have a Lofra Oven. Dont know what model. 5 burner gas multifunction. Probably 1100 mm wide. Trying to track down an Operating user Manual in PDF format so I can print off or...
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Mar 01, 2011 | Microwave Ovens
Oven racks missing
Most appliance stores that sell accessories have generic racks you can purchase.
Sep 28, 2009 | Microwave Ovens
Need help on how to change time on oven
To change the time push the clock button then use the key pad to enter the correct time and push the clock button a SECOND time.
May 20, 2009 | Microwave Ovens
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
