I am facing error BBlock v37 on my Zebra RZ400 printer. When giving a printer supply ? Then printer display show BLock v37 error. Please send me best solution.
Madbigwhoper
  • 13 Answers
SOURCE: there is error "bblock"
BBlock is BOOT Block. The printer is not booting up the settings completely. Probably got corrupted. You will need to download the bootblock version for this printer & upload it via either USB or LPT1 port. You should contact Zebra so they can direct you to the proper Zebra site for the download & instructions. The process of the upload is no more that 15-20 minutes.
Zebra phone # is 847-913-2259 I think option 2 is tech support. be sure to have s# of printer & tell them you need to find the boot block & installation info for the S4M. Good luck.
Posted on Feb 11, 2009
bartech9
  • 155 Answers
SOURCE: Z4MPLUS P3/P5 ERROR
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Posted on Oct 06, 2009
SOURCE: 10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Posted on Feb 20, 2010
techman007
  • 1112 Answers
SOURCE: The driver I installed is
Hello:
First go to the printers makers website and click on support, here you will be able to download the right drivers and manuals, even some of software that came with the printer. U did not mention which kind of printer to have.
Posted on Nov 10, 2010
ozztech
  • 285 Answers
SOURCE: LCD Display "BBLOCK V23" ?
it;s not a problem, they come like that dy default.
Posted on Feb 16, 2011
Why zebra printer supplies panel blink red light
The printer it is in error state? Any other LED it's blinking or lighted? Do you have any message on display? Please verify if the supplies are on the correct path. Do you use adhesive labels? Verify if there is any label (or pice of label) stiked on the media sensor. You can locate the media sensor using the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
Apr 24, 2014 | Zebra 105Se Thermal Printer
Prepare ZPL command for bitmap image to print a label
sir i miss my barcode i had applied for the post of subengineer in kseb thrissur my category no is 486/2011 my date of birth is 24-4-1978/and my mob no is 9526539897 please help me my mail id is sajithbose121@gmail.com
Jun 28, 2013 | Zebra RZ400 RFID Network Thermal Label...
Feb 10, 2011 | Zebra S4M Thermal Label Printer
Says paper is out says ribbon is out. Both are loaded properly. Says head is open. It's not. Turned off and on. Received error code bblock v23
I am having the same issue. Please help. Not having luck with this printer. I thought it was easier to print some labels.
Jun 23, 2010 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
I have a Z4m/sm400/105sl getting asame bblock error. I rebooted all, calibration and the same label keeps printing forever. It seems that nothng I do erases it from memory.
Disconnect the serial/parallel cable from the printer, it sounds like the print server itself is resending the label rather than the printer storing it in memory. Power cycle the printer after removing the cable(s) and you should be all set - but you may have to manually purge the job from the print server before reconnecting the cable.
Oct 20, 2009 | Zebra Z4Mplus Label Printer
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
My zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Mar 26, 2009 | Zebra Z4M Printer
There is error "bblock" on zebra s4m printer printer is not detecting with pc
Feb 07, 2009 | Zebra Z4Mplus Label Printer
Computers & Internet Logo
697 people viewed this question
David Payne
David Payne
