Question about Dell Inspiron 531s Desktop Computer
Checking file system on C test type NTFS freezes at 13%...I do not have the OP system disk and windows will not start normally or last known good config,,,,what do i do????
    Scholar:
  • 44 Answers
I have a Dell machine myself and if I remember rightly I think you press F12 to enter the Advanced Options menu. If you try to access this menu again when you turn on your pc you should see the following option safe mode. Try and get into safe mode if you can and this will load your windows desktop with minimum configuration. If there's absolutely nothing you can do to get into windows using these options then it may be a case of you trying to obtain and emergency boot disk. I don't know how old your machine is but the fact that it's a Dell is good. You should be able to contact Dell customer support and ask them whether they can send out the original disks to you for your system.
I called Dell when I purchased my Dell computer and they sent the disks out to me for free. Then it's a case of trying to reinstall windows using the windows installation disks. I have enclosed the link for Dell support below as follows:
http://support.euro.dell.com/support/index.aspx
What version of windows are you using, xp, vista, windows 7? The reason I ask is, failing the above options you can try to go for an emergency boot disk and the link is provided below. Do you have access to another computer, perhaps a friend whereby you can use the links? The link below provides an emergency boot disk but it only boots operating systems up to xp, there is a small charge but it's worth it if it means that you are able to get yourself out of problems later on. I think the best thing to do at this stage in anycase is to make contact with Dell. Good luck. Andrew
http://www.eddiemaintenance.com/purchase.html
Posted on Apr 05, 2011
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
My ASUS UX50 laptop has problems starting windows. Every time I turn it on it says "windows failed to start" and gives me the option of choosing safe mode, safe mode w/ command prompt, last known...
Seems like there are Operating System files that got corrupted. Try to boot the PC into the Windows OS setup disk. Run the setup, choose the currently installed Operating System then select Repair. For more details please check this link - click here
Hope this help. Goodluck!
Mar 28, 2011 | ASUS UX50VRMSX05 Notebook
Windows did not start ,drivers missing
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
When i turn on my laptop it goes to start windows normally or last known good configuration but when i select one it goes right back to start windows normally page again
Insert your OS system disk or recovery disk. reboot computer, boot from DVD, start installation of software, do not repair from the first prompt when asked, click install, once windows searches for previous version of windows click repair. This will reinstall the system folders and straighten out any registry problems. once complete you are done.
Nov 30, 2009 | Acer Aspire One AOA150-1784 Netbook
Installing xp
always use NTFS - NTFS is the standard file system of Windows NT, including its later versions Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008
Sep 10, 2009 | Microsoft Windows XP Professional for PC
Problem on start up of an acer 5630
Hi there
The drive is corrupt so you will need to plug it to another computer as a slave drive if you need the data from the drive, once you are satisfied you have all of your data you can then buy a new drive and proceed with a clean install of windows
Good luck and thanks for using Fixya!!
Feb 09, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Startup screen freezes
using the system restore disk, boot the laptop and choose repair, run chkdisk /r this repairs the system files, if this does not fix the problem, using the same system disk do a restore.
BPCS
Dec 06, 2007 | Dell Inspiron 8500 Notebook
LACIE Porsche 160GB
What system is the laptop? File differences is the ext-hard drive FAT32 or DOS? Therefore XP [NTFS] is not 'seeing' its content. On the XP machine go to start/Control Panel/Admin tools/computer management/storage/removable storage/and check the file type
Sep 27, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Dell Inspiron 531s Desktop Computer   Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
