Computers & Internet Logo
Posted on Aug 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Slow performance - Gateway Computers & Internet
Anonymous
Level 3:
  • Gateway Master 6,487 Answers
  • Posted on Aug 06, 2008
Anonymous
Gateway Master
Level 3:
Answers
6487
Questions
6
Helped
1557166
Points
18452
Slow computer can be cause of a low RAM of it and also if there's a lot of program/application install on it and also if there's any virus or malware operating on your syste.
The best that you can do first is to try to scan your system with a good anti virus like avast, avira and other to make sure your system is free from virus that may cause it to slow down then if still slow, try removing programs that your not using to free some resources for your computer and the best thing that you can do is try updating the RAM of your computer that will really make it faster..
Hope that helps.........
2answers
Mac M1 Pro 2020. How to fix it, slowness issue?
Question edited for clarity and toss in some CAPS.
It is a well known issue.
If you find your Mac is running slowly, there are a number of potential causes that you can check. Your computer's startup disk may not have enough free disk space. To make disk space available, you can move files to another disk or an external storage device, then delete files you no longer need on the startup disk.
If your Mac runs slowly - Apple Support (CA)
Apple Support https://support.apple.com > guide > mac-help > mchlp1731
macbook m1 is slow
Apple Support Community https://discussions.apple.com > thread
Jun 2, 2022 - M1 Mac Air performance degrades until restart My MacBook Air M1 (11.4, 16 GB) slowly loses performance over the course of 3-4 days on a regular ...
3 answers · Top answer: Hi, If you haven't reboot after update, try reboot the Mac. If it doesn't help, try to run ...
Do M1 Macs slow down over time, and if so, is there ...
Jan 8, 2023
MacBook 2021 M1 Pro slower than older 201...
Jun 12, 2022
M1 Macbook Pro 8/512 Very Slow Performance
Jun 5, 2021
16" MBP M1 MAX SLOW PERFORMANCE ...
Jun 17, 2022
More results from discussions.apple.com
M1 MacBook Pro becoming slower over time : r/mac
Reddit · r/mac 50+ comments · 2 years ago It looks like all the apps Adobe has running in the background has caused my Mac to slow. ... M1 Pro MacBook pro and it gets slow but restarting ...
My macbook air M1 8gb is lately getting slow - Reddit
Jul 24, 2022
Mac os sonoma is slow and laggy on my M1 macbook pro 8 ...
Sep 28, 2023
MacBook Pro M1 2020 running really slow : r/mac - Reddit
Jan 9, 2022
M1 macbook pro 14" ventura. Very slow finder and ... - Reddit
Feb 6, 2023
More results from www.reddit.com
Why Is My Mac So Slow? ' Speed Up Your Mac Now
Avast https://www.avast.com > ... > Performance > Speed
Jun 20, 2023 - Your Mac might be slow because of an outdated operating system or a full hard disk - especially if you have an older model Mac. If your Mac is ...
Why is my Mac running slow? · ‎How to speed up your Mac · ‎Now clean up your Mac
M1 Pro Max - Slow 6 Months in?
MacRumors Forums https://forums.macrumors.com > threads > m1-pro-ma...
Jul 21, 2022 - Seriously, just reboot it, and do so whenever the computer's feeling a bit slow. If you don't like losing context from quitting and restarting ...
tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 • Computers & Internet
How do I slow down the speed on Facebook
Change the settings using the Control Panel, Device Manager, Mice and other pointing devices application. Here you can slow down the scroll speed click sensitivity.
Slow running my tablet
remove unwanted applications, also the ones you dont use, reboot the tablet once, if still no help, download cleanmaster app its very nice
2answers
My iphone 3g getting slow
The problem may be because of virus in your mobile phone or memory full, download an antivirus or vacant some of your data. if it is not the problem than call your service provider.
2answers
3g iPhone switched to E even though i'm in my house and have full coverage so very very slow and useless! is there anything I can do or is it a chip problem?
The structure/location of your house may cause signal interference. One of my former workplaces had almost no signal throughout their building.
An easy solution would be to set up wireless internet at your home and switch your phone to wi-fi while you are home. This would actually be faster than 3g internet.
2answers
My iphone 3g is slow
The iPhone can be slow if you have too much on the disc. Closing running apps should also lakenene iPhone faster.
2answers
Slow start-up
check if you have a CD left in the cdrom drive.
Lots of things can cause the start-up delay too:
- virus and spywares. Clean.
- bad sectors on hard disk (backup and plan for replacement)
- low physical memory. check in the Performace tab of the Taskbar (window$$$ only) PF should not be more than that of physical
2answers
IPhone
Well try to restore your iPhone if that dosent help ask me
1helpful
2answers
PC slow performance
Well, based on my personal experience, that might not help overcome the pc slow problems. because there are a number of system issues might be affecting your PC's performance, some are dangerous while others not that serious. Learn why is your PC running slow and how to speed it up easily from: http://www.whyismypcsoslow.net/
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
