Question about Garden
Leplease explainon the safety switchs on mtd models660-679 work? I beleave my model is an intek twin. thank you
    Guru:
  • 1,833 Answers
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Posted on Apr 05, 2011
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
Aug 08, 2013 | Mtd Garden
I think i ran the engine out of oil . is there a safety switch on the engine?
some do some dont you will be looking for a sensor in the block with 1 wire
Jul 05, 2012 | Briggs & Stratton Briggs Stratton Intek V...
What's wrong when PTO won't engage? On my
should go from the switch to the safety switches to the clutch
Apr 01, 2012 | Briggs & Stratton Garden
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Battery is not charging. Does the Intek V Twin have an alternator and voltage regulator?
Yes, to both. Plug the model number in the searspartsdirect.com and you can get the parts listing & part numbers..
Oct 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Does the exhaust vavle have a stem seal on a intek twin cylinder?
Most do not. Check your exact model/type/code numbers on the parts lookup site here.
Sep 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
