Question about Samsung ML-2851ND Laser Printer
My ML-2851ND was on my old network with a static ip 192.168.0.1, just set up a new router, but the IP setup is 192.168.1.1 . . . of course the printer doesn't show, and the syncthru browser software won't get through to reset the IP to dynamic (or just reassign it to a nice 192.168.1.x #) Is there no way to reset it to factory defaults, or is this printer frigged now?
  • bob0183 Apr 06, 2011
    In the end, the is no way to 'flash' the printer to reset it to factory defaults that I could find. The web interface is the only way into the settings. That is the only way to change the printer from static to DHCP. I could not get SetIP to access the settings via a usb connection.
    My solution was to find my old router and access the settings via syncthru that way. Setting it to Dhcp allowed me access to the printer through the new router, at which point I set up a new static IP with the right subnet.
  • Van Karmaal
    Van Karmaal Nov 03, 2015
    Hi, There is another way round. Just follow the steps below and it works fine :
    1) Turn on your printer, wait until light is Green
    2) Press for 5 or 6 seconds on the main button (with orange circel/triangle on it) and release. This will print a page with network configuration of the printer : under the "Network Card" section, you will find IP Adress let's call it "A" to make it easier to use afterwards in the solution steps, Subnet mask let's call it "B" and Default Gateway would be "C"
    Now you have to be able to access your printer, but as its IP will be different, the network is not recognizing it. Here is the way around this :
    1) Connect the printer to your PC directly qith a network cable.
    2)Change your network card settings (ipv4) from automatic DHCP to manual and enter the "C" figure in the IP adress field then enter the "B" figures in subnet mask. Click aplply
    2) Open a browser and type in "A" figure means something like 192.x.x.x or whatever number is replaceing 192.
    3) This will open the printer config page and then you can setup
    THIS WILL NOT WORK IF THERE IS AN ADMIN PASSWORD ACCESS SET IN BY SOMEONE ELSE..
    After having done your setup either a DHCP either Static IP --> turn OFF.ON your printer, go back to Network Czrd settings of your PC and put it all back to Automatic DHCP or other config you might have.
    Reconnect your PC to the router and the printer to the router.
    Launch the printer discovery (option in the printer driver tool) and you will see your printer. That's it
4 Suggested Answers
  • 111 Answers
SOURCE: Printing is very noisy after
Please remove the drum unit and make sure that there is no rest of the paper in it then chek for paper from the back of the printer when you open the cover (some times a little pice of paper still inside).
Posted on Apr 10, 2011
  • 192 Answers
SOURCE: SAMSUNG ML 2851ND TONER REFILLED
you are using a mono laser printer
possible problem:
The surface (drum part) of the toner cartridge inside the machine has probably been scratched.
Remove the toner cartridge and install a new one.
Posted on Jul 17, 2011
SOURCE: IP address of printer on the network has changed
The SetIP utility does not do what you are suggesting.
1. If you want to manually configure the IP address on the actual printer use the SetIp utility to do that.
2. If you want to configure your computer to talk to the printer which is now found at a new address you need to do a "repair" install of the printer and the drivers will find the printer at the new IP address again.
Yes, it seems crazy but for some reason you can't "reset" the drivers to use a new IP address.
Posted on Feb 19, 2013
Printer lost static IP address with new router and won't install on network.
Your printer is looking for your old router.
Reset the printer:
  • Verify that the printer is powered on.
  • Press and hold down the Report Page button.
  • While holding down the Report Page button, press the Cancel button three times.
  • Release the Report Page button.
Now, re-connect your printer to you new router.
Source :
Re Can Get DeskJet 6840 To Work on Wireless Network Need HP Support...
Feb 12, 2014 | HP DeskJet 6840 InkJet Printer
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
How do I changed the IP address on Zebra 105SL Thermal printer? I need the steps on how to do it.
To enter Setup Mode, press SETUP/EXIT.
Press (+) or (-) until you get to IP RESOLUTION and then press NEXT/SAVE
Press the (+) or (-) key to display Dynamic or Permanent.
Select Permanent to give set it up for Static.
Go back to the previous menu and go into IP ADDRESS.
Press the (-) key to move the next digital position.
Press the (+) key to increase the value of the digit.
**The IP will not take if it is set to Dynamic**
To leave Setup Mode, press SETUP/EXIT.
"SAVE CHANGES" will display.
Select PERMANENT by using the (+) and (-) keys and then hit NEXT/SAVE.
You should now have the IP you put in configured on the printer.
Mar 02, 2011 | Zebra 105SL Thermal Label Printer
You have to use the utility call SetIP that comes with the printer. Check the CDs. It is easy to use.
May 16, 2010 | Samsung ML-2851ND Laser Printer
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
After changing LAN IP, can not access setup page
If using DHCP, reboot your machine or release and renew the IP on the network card. If using static IP addresses, change the computer's IP address to match the new segment and remove the old default gateway and replace with the new LAN IP.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Samsung ML-2851ND Laser Printer Logo
1,974 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
