Question about Canon LASER SHOT LBP-2900 Printer
Printer is working sir but paper is jammed i need help. recently i refilled toner, after this toner filling paper jamming coterminously please help me
    Guru:
  • 352 Answers
If this is the first time you have refilled the toner I would guess the Toner is the wrong type, has leaked out and is causing the paper to stick to the rollers. The only way I know of effectively cleaning this is to pull the rollers out, which involves pulling most of the printer apart. Its not a easy job.
Posted on Apr 05, 2011
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Paper jams
Please check the following steps:
1.Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Turn off the printer. Remove any paper trays. Look for damaged paper.
3. If necessary, remove the toner or ink cartridge.
4. If you find a piece of jammed paper, remove it.
7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8. Replace the toner or ink cartridge and paper trays.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
I recently changed cartridges and now the paper always jams
If you put in a generic or refilled cartridge, it may not be turning well. Many generics are overfilled and actually cause damage to the printer. With the toner and drum out, check inside for any scraps and turn over the drum unit and check for scraps under the silver bar on the bottom.
Feb 22, 2010 | Brother HL 2140 Laser Printer
Paper Jam at the printer
please do the following sir: 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Feb 09, 2010 | IBM Infoprint 1612 Express Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Hi sir HP Printer 1022 paper jam problem
turn off you print and remove the toner and remove the jam paper and shake then place the toner back and on the printer then you will now restart you system which you place your printer on it will work like that a
Oct 24, 2009 | HP LaserJet 1022 Printer
Lexmark C760 problem
r u using refill toner than spill over will happen
use good quality toner
plus clearn the ITU drum regularly
if using genuine toner than demand replacement fm lexmark for this problem
Jun 18, 2008 | Lexmark C760 Laser Printer
Paper Jam at 2
Its probably not picking up paper from that tray, thus the jam error. For me that is typically because the tray isn?t pushing the paper up high enough to be caught by the pickup roller or the pickup rubber band is worn.
Feb 02, 2007 | HP Color LaserJet 2600n Printer
Canon LASER SHOT LBP-2900 Printer Logo
65 people viewed this question
old marine
old marine
