Trying to light pilot not sure where to light at hear gas come on n not sure how to or where to light
  • 1 more comment
  • Roger Jelinek Apr 05, 2011
    Can you explain in more detail of what it all looks like? A picture of the burner compartment would be great. If there is a 1/4 inch aluminum line on the gas valve, follow it. Depending on the unit, that probably goes to the pilot assembly. Please vote on this response. Thank you. Roger
  • Rich Landrum Apr 05, 2011
    For safety's sake, we need to know what make and model your heater/furnace is , to help you.
    Scholar:
  • 133 Answers
Follow the 1/4 inch aluminum line from the thermostat. It feeds the pilot. Please rate my response to your question. I am new to this site and need to improve on how I relay the information. Good or bad is OK. It all helps. Thank you for writing FixYa! Roger
Posted on Apr 06, 2011
My 32000 btu unit lights and runs when it reaches desired temp and shuts off the pilot stays on and you hear a click then a minute later a second click and the pilot light shuts off.
The clicking you are hearing is the gas valve trying to open but because the pilot light is out the valve shut back off. Sounds like the thermocouple is bad on the unit. The thermocouple sits net to the pilot light and allows the gas valve to open. Hope this helps.
Dec 17, 2016 | Heating & Cooling
How do you light the pilot
Turn the gas knob to the pilot setting, press it in and hold it. You should hear gas escaping while in this position. Do not let more than about 10 seconds of gas out at one time as it may pool. Light the pilot while holding the gas knob down for a minute. Release the gas knob (the pilot flame should stay lit) and turn it to the ON position. To make sure the gas heater is working properly, turn up the thermostat and see if the heater heats up. How To Light The Pilot Light On Gas Heater
Oct 19, 2016 | Heating & Cooling
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
Full tank, igniter clicks, i hear the flam come on but it wont light. What to do?
I am not sure which flame you hear light. The pilot light flame or the burner flame? In any event, the burner and the pilot assembly need to be cleaned. Insects love to build nest in these types of heaters, when they're not in use. When that happens, the pilot and/or the burner get's clogged.
A shop vac with a hose and brush attachment work well in cleaning the heater parts. Canned compressed air with a straw nozzle (like you clean your computer with) does well in blowing out the pilot tip and around the entire pilot assembly.
Be sure to turn the gas tank valve OFF and disconnect the hose and remove the tank, before attempting to clean the unit. When you replace the tank and reconnect the hose, be sure to open the gas tank valve VERY, VERY SLOWLY (Slow motion slow).
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 21, 2011 | Endless Summer 200209 Open Flame Patio...
I am a new homeowner. I have an H400IDLunit that is a pool/spa combo. The code reads "00" in the heater window and does not change when the unit controlls are pressed. I have an aqualink...
I don't know if there is a pilot light, spark ignitor or thermal ignitor. I would determine by inspection what kind it has. If you open the front cover you will find a gas valve. It can be identified by following the gas pipe that enters the side of the heater and attaches to the gas valve. If the valve has a control knob on it that has an off, on and pilot position then it is a pilot type. If this control is not on the valve then the unit includes an automatic ignitor.
To light a pilot equipped system place the knob in the pilot position, push it down, and use a flame to light the pilot. If you hear gas flowing from the pilot but it won't light then there is air in the line and it needs to be purged. Holding the pilot lighting valve down long enough will purge it but may take a long time. Periodically you can check it by trying to light it. If it lights watch it for a while before trying to turn the heater on to make sure it is fully purged. Once the pilot is stable and the thermocouple is heated the pilot valve can be released and it should stay lit. If not, try again.
Don't get down and look into the burners while you are trying to start the system because it could flame out and burn your face. If you turn on the heater again then the gas valve should come on and the burner should light. You can usually hear a loud snap when the gas valve come on. You should then hear the gas flow to the burner. If the burner doesn't light you should be able to smell the gas. If it lights exhaust will be coming out of the vents in the top of the heater.
I am sure you will have more questions so please respond with them. I hope this helps.
Sep 04, 2011 | Hayward H-series Electronic Gas Pool...
Not sure how to get the water heated. I've turned on the enterior switch and the switch on the back of the unit and tried to light the pilot but don't here any gas coming through at all.
OK this systems has a safety system and it will not let gas pass threw without the pilot light working correctly. first off near the pilot light there is a thermal coupling. this sends a signal to the main valve to open up. this thermal coupling need to get to a set temp. (hot) this is probably why you don't hear the gas. check if there is a manual bypass valve for maintenance. check if you can light the pilot rite away if you power the system on. it also has a time delay so the pilot won't give gas out if not fired on. sometimes there is a manual nozzle you have to press and hold till the gas pilot warms up the thermal coupling. hope i help some. thank you.
Jan 14, 2011 | Attwood 12V Shower Pump System 750 GPH...
Can not get pilot to lite was working fine had to turn off gas will I changed out some water pipe went to relite and could not get pilot to lite
I would first make absolutly sure that I had all air bleed out of gas line to water heater. If you are trying to bleed air out thru pilot assembly this can take a long time because the opening in pilot orifice is very small. To speed up process if you have a union close to unit or flex connector,you can slightly loosen fitting till you can hear a little hiss of escaping air/gas. When you first smell gas immedieatly tighten fitting. Before you do this make sure there are no standing piloy lights or other sources of flame in the vicinity. When you smell gas and tighten fitting back up try to relight pilot to water heater.If you still can't get pilot to light I would remove pilot line from gas valve and burner. Check to see if you can blow thru it, visually inspect pilot orifice, and if blocked I would get a orifice cleaning tool from hardware or welding supply store. Be careful to select the right size for your orifice and clean it. Reinstall and try to light pilot again.Hope this helps. Thanks
Nov 17, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
I have an older monterey wall heater that is gas that wont seem to light. I cant even get the gas to start from the pilot can you help me?
You could have a plugged pilot line. You will need to get to the gas valve and shut the gas supply off. Once you did that, unscrew the pilot line that supplies gas to the pilot assembly. You can then turn on the gas supply and rotate the pilot knob to the pilot setting. Depress the knob into the gas valve. You should be able to smell and hear the gas come out of the hole where you unscrewed the pilot line. Don't do this with a cigarette in your face. Once you verify you have gas, release the knob and shut off the gas supply. Take a can of air and blow thru the pilot tube, first from the pilot assembly in the heater then from the open end of the pipe. Replace the pilot tube making sure you don't cross thread the fitting. Tighten well. Again turn on the gas supply, spray or rub some soapy water on the fitting you tightened, depress the knob and hold it. The soap will bubble up if there is a leak. Fix it. Now light the pilot.
Jan 20, 2010 | Heating & Cooling
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
