Question about Dishwashers
Water not pumping out of dishwasher - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Apr 05, 2011
Pumps water in don't wash and pumps out again
Not sure whether a schematic will help unless you have some understanding of the location of the components. It would help if you are able to clarify what you mean by pumping in. Usually you should hear the water inlet valve turn on to let water in. Then the wash motor should run to churn the water around and then the drain pump should drain the water out. What is happening is the dishwasher is leaking water as soon as it fills. This causes the flood switch to turn on and that triggers the drain pump to empty the water. Usually Bosch dishwasher have an inline water leakage detector. Check under the sink where water inlet tap is located. There is a device connected through which the water get in. The hose is detecting leakage. Need actual model number of the dishwasher to investigate.
Apr 07, 2014 | Bosch Dishwashers
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Water not pumping into dishwasher - model G664I
You probably need a new inlet valve. Cheers,Derek.
May 19, 2009 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 | Dishwashers
Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Feb 01, 2009 | Bosch SHU5315UC Dishwasher
Drain pump won't stop
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
Nov 22, 2007 | Bosch 24 in. SHX36L05UC Stainless Steel...
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Sep 12, 2007 | Dishwashers
Dishwashers Logo
161 people viewed this question
Top Dishwashers Experts
