Question about Hobart H600 Stand Mixer
Hi, The motor on my Hobart H600T, is burned out (lots of smoke, and the internal wires seems to be damaged). I'd like to know where to purchase one (new or used), and what could be the price. thanks. Stephan
  • Hobart Expert
  • 119 Answers
Go to www.hobartservice.com and click on "locate an office". Enter your zip and call or email the local Hobart office. They will be glad to help.
Posted on Apr 14, 2011
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Hobart h600t . Makes noise on speed 3 and trips on overload. I checked start cap all electrical components all look normal.
I'm having the same problem cap and all look good but still the motor won't run and the the overload trips the breaker
Jan 13, 2014 | Hobart H600 Stand Mixer
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Sep 05, 2011 | Hobart H600 Stand Mixer
H600t has a grinding sound when engaged
All you can do is take to top off and look inside. Look for damaged gears, shafts that move sideways slightly (or more than slightly) when power is applied, that sort of thing.
Also look for a worn gearshift. Be sure that it engages fully in each gear- observe and see how the mechanism works, there's an overrun clutch with dogs that can drag if the shifter is worn or out of adjustment.
There's not much to go wrong with a Hobart, they seldom fail and are generally easy to repair. Replace the grease while you're in there, if you don't like bearing grease call around and find some food grade grease, a lot of auto parts stores carry it now.
lp
Jan 16, 2011 | Hobart D300-6036 Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
What type of oil goes in trans of h600t mixer
the oil part# is 102973-71, you can go to any hobart office in your area to get
Dec 09, 2009 | Food Mixers
Hobart N50 stator assembly replacement
You can go to www.hobartservice.com. select parts and type the machine ML number from the data plate. here are 5 different ML options, otherwise I would have given you the part number.
It will open an exploded view of YOUR machine's build, complete with part numbers.
You can then call your nearest Hobart dealer for a cost and availability. They are still a current model, and for their size, an excellent mixer worth repairing.
Aug 18, 2009 | Hobart N50 Stand Mixer
What type of oil is used in hobart-h600
hi / I have to chang hobart mixer h600t oil seal on the end of dough hook , but not sure how ? please let me know if any one
knows about that
Jun 23, 2008 | Food Mixers
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart H600 Stand Mixer Logo
132 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
