Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
My printer is snatching paper. - Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
3 Suggested Answers
tech-agent
  • 83 Answers
SOURCE: hi the paper feed pulls the paper into the printer
***hi there,il be willing to help you on that. ****
there is a great possibility that the rollers of the printer is having an issue. but try there steps first , do a self test on the printer, run a blank sheet of paper, if it jammed, that means the printer itself is broken
put plain paper in the sheet feeder, then press the start button. if it jammed, remove the paper jam and try again.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Posted on Feb 17, 2010
  • 6 Answers
SOURCE: Paper feed "violently snatches" more than one sheet of paper
ok its possible that something may have dropped into it, you would not believe the things i have found in mine:), a paper clip the other day. you could unplug it completely and turn it upside down and give it a little shake but not to hard, or try a torch first,
Posted on Apr 19, 2010
My printer says the number2 the e what should i do i have replaced the ink
E, 2 is an alert that the paper is not as being correctly loaded into the paper tray. Remove your paper and get a fresh, dry supply of new paper. I suggest using only five pages or so, and separate them to remove static. Place them into the feed tray and get the guides so that the paper is properly aligned...not too tight and not too loose. Try printing. If you continue to get the error code, remove the paper and make sure there are no obstructions anywhere in the paper path. Sometimes when users get a jam, they snatch or roughly remove the page and tear tiny pieces off that remain inside and can block sensors. If you find any bits of paper, remove and cycle the power and then try to print again.
Apr 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Apr 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam as snatches paper in on right hand side, then displays E 3 and does not print
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Hi the paper feed pulls the paper into the printer with a snatch type action and on one side of the paper causing it to jam ? the printer is a epson DX5000/CX4900 series.
Feb 17, 2010 | Epson Office Equipment & Supplies
When the printer is switched on the red ''Resume'' light flashes and the printer ''snatches'' at the paper but does not print.
there is a paper feed roller... right by the paper... clean it with rubbing alcohol or isopropyl alcohol and try again...
Dec 09, 2009 | Office Equipment & Supplies
I was having a printing on animal care (book) It had 164 pages so I stopped the printing now it starts printing the book all over. How do I cancel this book? Canon iP1800 series
itz problem/error of print pooler..
often happens due to data resent viz. reprint/overload/document mismatch/page error and so on..
itz very common..don't panic..!!..
snatch out all the paper(s) in the tray (but not which is printing)..set all the document in the print pool to delete..just turn off the printer..restart the system..
hope it'll b fine..
best to seek guidance of ur system admin/vendor....
Nov 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
THE PRINTER WONT WORK IT JUST KEEPS SAYING NO PAPER FED WHEN PAPER IS FED
First of all, check that the paper size setting is correct in the printer and in your software. Sometimes the printer tries to tell you not that "there is no paper" but that "there is no PROPER paper", e.g., you send a B5 printing job when the printer has A4 paper in it.
If this is not the case, we have to assume the problem is hardware.
Take out the paper and look where the paper should go. Insert a single sheet and look along it for help. You should see a small plastic leg dangling down from the left upper hand side of the paper feed slot. That's the paper out sensor.
If you can't see it, it could be broken - in that case the printer will never see the paper you put in. Or it could have stuck in the forward direction (it can happen if somebody overfeeds the printer or tries "snatching" the paper when it's half captured by the rubber roller). If this is the case, GENTLY rapping on it may dislodge it and send it dangling properly on the paper path.
If you can see it, and it dangles properly - it's not skewed or bent and does not appear damaged - try blowing along it with a compressed air can. Sometimes a bit of paper dust can lodge in the optoelectronic "window" and blinds the sensor.
All other likely damages, unfortunately, aren't easily repairable except by a skilled technician with the appropriate spare part.
Oct 05, 2009 | Brother MFC 420CN All-In-One InkJet...
After a paper jam my printer display panel says - unable to print 50 what should I do
got some part of the cable that attach to the Mainboard have snatch usually it is the ink sensor ...
Apr 25, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam X6170
Yes, this is a paper jam. Open up your printer as if you were changing the ink. Get a torch if needed and a pair of tweezers in case it is small. Get in ther and have a good look for it. It can be so tiny and could be near the carriage that is off to the side, in the roller and its teeth or further down. he paper cruching is because of the jam and the fact the carriage cannot center itself. Good luck.
Oct 22, 2008 | Lexmark X6170 All-In-One InkJet Printer
Paperfeed snatches the paper
It is usually the same with most ADF's if you put in a single sheet.
Oct 18, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
old marine
old marine
