Question about Hobart H600 Stand Mixer
How to replace a driven belt for hobart M802 MXER?
2 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: Need replacement motor for Hobart M-802 mixer
Hi Dan. Two options. The first is to call Hobart and ask about a temporary replacement mixer while your original motor is being rebuilt. They'll charge you for it, if they will do it at all. If Hobart is doing the rebuilding, they might give you a better price or a free loaner.
Second. eBay often lists hobart motors for sale, you might get lucky and find one quickly. Since you absolutely must have a working mixer for your business, you might consider having a spare motor on hand for just such an occaision.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on May 05, 2009
Why bowel not lifting after i put together
This is a kitchen device (mixer). I suggest you stop trying to use it as a medical device.
Jun 01, 2014 | Hobart M802 80 qt. 3 HP Dough Mixer
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
May 05, 2009 | Hobart Food Mixers
90quartmixer gears dont have power belt torn
Is the model an M802?Did the belt break or slipping?I'm a hobart tech,let me know.
Mar 03, 2009 | Hobart H600 Stand Mixer
Looking for location of drain plug for m802
Look behind where the dough hook is near the pedestal,its a three quarter inch bolt.
Feb 21, 2009 | Hobart Food Mixers
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Hobart H600 Stand Mixer Logo
114 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
