Question about Roper REX4634KQ Electric Dryer
I have a roper RES7646KQ3 and it has worked fine, and withing the last couple weeks it hasnt been drying the clothes as well and now it wont heat up at all?
    Problem Solver:
  • 18 Answers
Usually the heating element starts to burn out just replace
Posted on Apr 05, 2011
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Hi i have a roper electric dryer and it will go threw all the cycles but wont dry clothes like wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Roper REX3614KW Electric Dryer
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
My son put soaking wet clothes in dryer....since then clothes wont dry (happened 2-3 weeks ago) took hose off back and ran with it off....still no heat.....help! john
I would check for a blown thermal fuse or faulty heating element. These components can be tested using a multimeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located in the rear of the dryer, usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 04, 2009 | Roper Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Res7646kq3 roper dryer
Yes UNPLUG and open the back of the unit on the bottom right side you will see the element in a heat chute that model has what I call a half element it mounts on the bottom portion of the chute just remove the 1/4" screws and the high limit stat and you will see how the new one goes on
Feb 17, 2008 | Roper REX4634KQ Electric Dryer
Re: no heat and timer not moving
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Roper RES7646KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
74 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
