Question about Compaq Evo N1000C Notebook
Hard drive error
Hi, I installed a 250GB hard drive and it was working with no problems but suddenly I am getting a hard disk error before any attempt to boot up. Using the repair facilities with the Windows XP CD I have done a chkdsk - no problems. Also did a fixMDr and fixBoot and no problems. Have I got a BIOS problem?? Please help
  • 2,794 Answers
Go into the BIOS setup and see if it detects it.
How old is that computer?
Posted on Aug 05, 2008
My Hitachi Simpledrive Mini 250 suddenly quit....when I lookein the device manager it said Code 10, would not start????
Sounds like a disk error and it cant read the start of the drive. If it still detects it you might be able to repair it with a partition recovery or partition repair tool available online.
Dec 11, 2014 | Hitachi SimpleDrive Mini 250GB USB 20...
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
Hi, I have Transcend Storejet 250GB Hard disk. I bought it in Jan 2010, It was working fine earlier but suddenly one day it was not detecting in my laptop but its LED is glowing. Its also not showing mass...
Hi Welcome to Fixyah,
For that case you need to detouch the enclosure of that device there must be something wrong with the enclosure. No worry the disc inside of it is not affected. You need to get the support coming from your reseller because I believe it was still under warranty.
Aug 12, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Goes to intel screen thEn black screen with
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way. These disks will run you about $15-$30
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
Thanks for using Fixya
Nov 08, 2009 | HP Pavilion dv6000z Notebook
250gb hard disk not working
Your HD has an obvious problem. If it has power going to it and it isn't working then the HD needs to be replaced. Don't worry in many cases you can have the data retrieved from your old hard drive by using this online company that I highly recommend:
Jul 05, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
What does ' a disk read error occurred press ctr alt del to restart, everytime i do it it gives me the same error??
You could have a hard drive problem. To check the hard drive boot up to the Windows XP cd in repair mode. At the C prompt type: chkdsk /r
This will start a program called Check Disk that will evaluate your hard drive and attempt to fix any errors. it Check Disk is successful it will complete 100% and return to a C prompt. You can then attempt to reboot. If Check Disk finds unrecoverable errors you will need to purchase a new hard drive and rebuild the OS.
Jun 14, 2009 | Gateway MX6453 Notebook
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
Dec 31, 2008 | ASUS M2N-E Motherboard
175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Compaq Evo N1000C Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
