Question about Stainless ILVE MD-100F-MP Steel Dual Fuel Range
An Ilve JC80 LM with a broken oven function hello. The knob is fine it is the shaft that is jammed and won't turn. What part is required, how to fix it?
    Guru:
  • 257 Answers
Hello nickypaige,
The only place you can get parts is at the following web-page and you have to go threw there department. You will need a new oven control. Follow this link to get your parts http://ilveappliances.com/part.php
Thank you for choosing FixYa.com
Justin
Posted on Apr 05, 2011
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
Hi, my ilve oven made a bang last night blew the fuse in the fuse box, which I replaced. The lights and fan on oven work but there is no heat.
Hello westcowie, ILVE Service here.
First check that your oven's time is set. If the clock is not set the oven will not work due to a safety feature following a power outage?
If you continue to experience problems please contact the National ILVE Service team on 02 8569 4672, or via the ILVE website at http://www.ilve.com.au/contact-us
Thank you, we look forward to helping you with this issue.
Kind regards, ILVE Service
Jun 14, 2011 | Kitchen Ranges
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
The stem/shaft that holds the oven knob seems to be broken--the knob turns but does not turn the shaft. Is this a repair an amateur can do and what part do I need?
first pull the knob off the shaft and check to see if its broken where the shaft is supposed to lock-in if so u jus need a new knob. if not you have to pull the panel off the stove and replace the shaft this shouldnt be too difficult either way.
Jan 24, 2011 | Viking 27" Professional Select Built-in...
Broken oven switch
Hello- Parts for this unit are available directly from the manufacturer. Contact them through e-mail or phone at Ilve.com.au  They should be able to get you the part. Although I'm 'up-top' in the US, and not familiar with how difficult replacing the switch might be, looks like they have service support so ask questions! Please acknowledge this post if helpful. Thanks- Ed
Mar 23, 2010 | Ovens
Ilve electric oven modle P 90 WMP. the digital
on the back of the clok is 4 wires the brown and the blue suply power for the clock and timers functions the 2 reds the timer makes these live if only one is live when set to manual then its best to replace the clock or if you can change the relay that the wires ar conected too
Jan 24, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Oven won't heat up to set temperature
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Apr 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stainless ILVE MD-100F-MP  Steel  Dual Fuel  Range Logo
298 people viewed this question
Top Stainless Kitchen Ranges Experts
richie46
ray gallant
Bill Boyd
Are you a Stainless Kitchen Range Expert? Answer questions, earn points and help others
