Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Ran descale program and coffee still tastes funny (bitter)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Posted on Apr 28, 2011
How can I avoid bitter coffee?
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
Espresso Machines Coffee Makers Grinders Reviews
Sep 08, 2014 | Coffee Makers & Espresso Machines
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Why is coffee bitter?
Bitterness is a dominant quality in the overall taste of coffee. You need a certain amount of bitterness to balance out the flavor. There are two types of chemicals that give coffee most of its bitter taste - both are antioxidants.
Jan 10, 2013 | Wine & Spirits
Making very bitter espresso. I already decalcified it and ran empty tanks through, without success.
Hi. The bitterness you have got is most likely to be dirty group head and shower. Remove the shower and clean with a steel wool. The group handle and filter basket will also have to be cleaned. Sounds like your using a dark oily blend. You cant use different blends unless you clean the group head every time. Same with the grinder. You can not use different blends for grinding. The different blends just cross contaminate, which can make your coffee bitter. Incorrect grind or wrong water tempreture can also make bitter coffee. Running descale does nothing for the coffee taste. Descale only cleans the lime/calcium in the boiler. Coffee does not pass through the boiler. Give your group head and handle a clean, and you should be right. Hope this helps. Dazza
Oct 21, 2011 | Saeco VIA Venezia
My coffee tastes bitter and water is not hot
You need to delime or descale the unit with white vinegar, that will clean it out
Go here to get the manual and it will tell you how to do it....
http://www.retrevo.com/support/Delonghi-EAM3500-Coffee-Makers-manual/id/3878ci577/t/2/
Aug 07, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
The red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Feb 03, 2009 | Saeco Aroma Espresso Machine
Coffee tastes like metal
THIS HAS NOTHING TO DO WITH THE COFFEE. This has to do with water filter system and most importantly descaling of machine, as over time the metals in side machine and tubing get a mold type build up. Its a chemical reaction from the water and tubing and the coffee and metals. To 100% solve this, descale the machine with water and vinegar mixed. Do this a couple of times and use bottled water to fill water tank if you do not have a good water filter tap system. I have been the espresso business for over 16 years with 4 locations, and it has nothing to do with the coffee. If it was the coffee or poor coffee it would tasted burned or bitter, but NOT tasting like metal.
Please rate my solution as you see helpful, Thanks Mike Espresso Expert
Jul 02, 2008 | Dacor CM24P-1 Coffee Maker
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
2,458 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
