Question about Vacuums
Sewing Machine..I've just unpacked my old Lemair 604 (yes it was mums before me) and it's been a while - too long - since I efficiently sewed happily away, I couldn't remember and eeek the manual is gone from the case..some rotter didn't care enough when they borrowed it. in essence the manual for my Lemair 604 sewing machine has been lost. It seems very noisy and tight and I dont know how to adjust the tension or thread the bobbin correctly or where and how often I should oil.. Can you help?
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
SOURCE: i have the brother Ls-2000
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Posted on Feb 07, 2011
HansPP
  • 2510 Answers
SOURCE: I have a 3 year
This might sound too basic for you but check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
images?q=tbn:and9gctyfr7tkfpdipppvqt_-ka70owyny1t5tzdw5qtysow1a3fr_qmpji113vk
Posted on Feb 26, 2011
HansPP
  • 2510 Answers
SOURCE: Thread and bobbin both threaded
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 16, 2011
FitzOriginal
  • 842 Answers
SOURCE: I've lost my user manual
You could email: spares@aeuk.co.uk and ask for a manual or call (+44)1322 291137 x 2 between 10:00 and 14:30
Or (Thanks to an article 10 months ago from Farmerbear) you could go to allyint.com
They are the sole US importer of the Necchi machines and I believe they stock replacement manuals. Their number is: 1 800 525 9987 ex 20
Posted on Jun 30, 2011
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
Where can I get my Elna machine fixed? It is quite an old model and the zigzag function is broken. I am in the Toronto Downtown region.
Here is the email address for Great Western Sewing Machine Services in Toronto: brian@gwsms.com
He was the service manager for Elna, Toronto for many years.
Also, Norm Sewing Machine provides on-site servicing. Here is there phone: 416-993-4466
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Vacuums
Sewing machine problem. . . . . .Hello Rick, My machine is an old Bernina 830. The instructions in your blog make sense and should have fixed my problem, but didn't :-( Question: There are 2 pins that...
Yes, from the information I have on your machine the metal disk you refer to is basically a program disk. It operates like the old self playing pianos did with the holes. You stated that the model number is 830. Is that the model number that is written on the machine?
Jan 17, 2011 | Vacuums
I am looking for an instruction manual for the joys PF1600 sewing machine for my mum, and cant seem to find one anywhere. can you help
Are you still looking for this? My girlfriend has the exact same model and i could copy the instruction manual for you. -Ming
Sep 09, 2010 | Vacuums
How old is the singer sewing machine with the serial number g1027369
You have a Singer Model 27, built at their Elizabethport factory in Elizabeth, NJ, in a production run of 40000 which were manufactured in 1911. Confirmation from Singer available by clicking here.
Your machine is very nearly 100 years old, but in good condition will still be fully usable and you can still buy many spare parts for it.
I trust that I have fully answered your question; please take a moment to rate my reply.
Sep 04, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
