When I start up my aoc monitor, it will be fine for a few seconds, then will shut off and all the buttons on the bottom will blink. I can get it back on by unplugging it from the back (only after a lot of waiting) but it has to cycle through this about 8 times before it just stays on.
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 05, 2011
  • Brian Sullivan
    Brian Sullivan Apr 05, 2011
    another possible reason could be a memory dump you might be running to many programs at the one time also you might not have enough ram random acess memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click om my computer select properties you will see all of your computers details
Aoc led monitor has a vertical jitter seen on letter and picture
Unplug the monitor from the back of the computer and wait a few seconds until it displays a message "No signal." If the no signal message also has vertical lines, you know the problem is in the monitor and not in your computer. Press the "Menu" button on the screen and then use the other buttons to browse for a "Factory Settings" mode. Select this mode to reset the monitor to its original settings. If the lines persist, the monitor may have been dropped or exposed to a magnet -- which can't be fixed.
Aug 18, 2017 | AOC Computers & Internet
AOC 2036s shuts off after seconds
my aoc monitor 2036s is blinking when i run hd movie or play game . what can I do for fix my problem. please suggest....
Jan 28, 2012 | AOC Computers & Internet
When I boot up my PC the monitor will blink the windows logo and sign on for a second then go black....if I turn off the power button on the monitor and pust it back in the monitor will again blink the...
Could be the resolution too high for the monitor.
Try to press "F8" during the "Starting Windows" message, then select the safe mode or VGA mode.
After logging in check the resolution and if needed reduce it.
Could be also a video driver problem.
Use the same "F8" trick to get to the safe mode and reinstall the video driver.
I hope this will give you some ideas
Apr 05, 2011 | AOC LM729 17" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
AOC lm720 no screen plus blinking green light
Sorry to say, but it sounds like you power board is due for an overhaul.
It should be fixable since it does show signs of a little life left in it.
It would have to be taken apart. A visual may tell for sure.
Look for bulging capacitors (canister looking things) This a sign of a typical failure.
Of course, not all capacitors bulge when they go bad. That would make things too simple !!
ebaysbammbammfran
Oct 12, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
