Question about ASUS P5P800 SE Motherboard
Asus P5P800-SE w/ Bios upgrade 0805
Hi id like to ask if my mobo supports a dual core or core2duo processors,
ive already upgraded my bios to 0805.
thak you
  • Pak3rs Aug 06, 2008
    Thank you,
    by the way my PC specs is :
    P4 3.2ghz
    Asus P5P800-SE
    1x 320 Seagate Sata
    1x LG 20x LS Sata
    385 HEC Dual Fan Power Supply
    Nvidia 512mb 7300GT
    Zalman's CNPS9500 CPU cooler
    im planning to upgrade to Pentium DC E2200 (2.2G) 1mb 800FSB, do i need to upgarde my Power Supply too? like up to 500w?
  • 2,794 Answers
Click on this link to get the specs
It does support dual core.
Posted on Aug 05, 2008
SOURCE:
I installed the Windows Server 2012 R2 on this machine, and I-m trying to upgrade the bios since at the boot, it says that I need to upgrade to unleash it full power. Nevertheless, when I execute the Bios...
Run the Bios upgrade from a floppy also make sure that you don't have a write protect enabled for the the bios. you could also boot from a hbcd disk and run it from xp mode and put the floppy in a then run the program. good luck./
Mar 27, 2015 | ASUS RS100-X5-PI2 - RS100-X5-PI2 Barebone...
Can a Biostar NF61S MICRO AM2 SE (NF61MICROAM2SE) Motherboard run a AMD dual core X2 7750 2.7
Hello look here for the cpu list:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=23#cpu
Try also to look in the manual.
I think it will fit, but you probably have to upgrade the bios, to support the new cpu.
Good luck
Dec 19, 2012 | Biostar NF61S MICRO AM2 SE...
Just built new computer using an ASUS Z8PE-D12 motherboard. When I power it up, it keeps wanting to flash the bios. I just had to replace an identical motherboard doing the same thing. Removed all...
z8 is nice, I know for sure,
Z8PE-D12 the dual xenon server grade mobo, like my z600 works station has but HP made.
let me guess both boards never worked for you and you bought them on fleabay, and are DOA? that it, what is the story here.
Let me guess more, (no history at all)
you just put in a new CPU, xeon, ?
well if you did and
1: it is not support, it will do that.
2: or it needs flashed bios to support newer xeons.
3; no you can not run all xeon's made in this mobo ever.
first off put only one xeon the primary socket.
and only ram for just it.
then at ausu we site makes sure you are using the right xeons first.
the correct path is with working xeon, flash the bios.
then upgrade xeons last.
ok?
5500 series processor
1366 socket
Six-Core/Quad-Core Intel® Xeon® X5600 Series (130W)
Six-Core/Quad-Core/Dual Core Intel® Xeon® E5600/E5500 Series (80W)
Quad-Core Intel® Xeon® W5500 Series (130W)
Dual Core/Six-Core/Quad-Core Intel® Xeon® L5600/L5500 Series (60W/40W/38W)
Six-Core/Quad-Core Intel® Xeon® X5600/X5500 Series (95W)
here is the offical list.
newest BIOS is 1401
i bet yours is super old bios and not stated, or what xeons you have.
as you can see it is not trivial this topic.
https://www.asus.com/Commercial-Servers-Workstations/Z8PED12/HelpDesk_CPU/
it seems owning just 1
Dual-Core Intel Xeon E5502
as cheap as $5 60 on fleabay will allow flashing this mobo firmware, worst case.
Feb 06, 2018 | ASUS Z8PE-D12(ASMB4-IKVM) Dual LGA 1366...
Hello, I have an Asus P5Q Se Plus motherboard with a Dual Core 8500 Intel processor. I recently upgraded from vista 64 bit to Windows 7 64 bit ultimate. It installed correctly, all the drivers are up to...
The same happened with my Asus P5Q MB,
I've updated the BIOS to the latest version, and every thing was OK.
Please, Tell us your results.
Good Luck
May 18, 2011 | Computers & Internet
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
Memory Issue
yeah you should upgrade. Windows xp 32bit only support up to 3gb memory. You should upgrade to 64bit.
And your specs? Yeah it can run 64 bit operating systems or if you like, use Windows Vista x86 or x64 with Service Pack 1.
Sep 24, 2008 | Microsoft Windows XP Professional x64...
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Mar 21, 2008 | ASUS P5PE-VM Motherboard
ASUS P5P800 SE Motherboard Logo
684 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
