Question about Philips GOGEAR SA6045 MP3 Player
The philips go gear mix 2GB doesnot play, it updates to only 40% as i turn it on, and then it shuts down automatically. Guess some internal file/software is missing, i might have deleted it by mistake
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips Device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Posted on Apr 06, 2011
  • saudamini03 Apr 07, 2011
    i guess some of the contents of my philips go gear mix have been deleted by mistake. where do i get hold of these contents from? is it available on the net?
  • Ritesh Thakur Apr 08, 2011
    Please visit www.philips.com/support
PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
Philips GoGear Mix MP3 player. Copied MP3 files to device.. Fully charged. When I turn it on, it starts updating to 40%, hangs, and shuts off. Help
I had the same issue reset the player and continue holding down the reset button. Then turn the power on while still holding the reset button it'll shut back down, but when you turn it back on it should work.
Jul 04, 2011 | Philips GOGEAR SA6045 MP3 Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
My laptop shutsdown automatically after showing the dialog box of shutting down even after canceling the shutting down option whats the matter to my mac !!!!
reset the smc and pram followed by Apple website, also check the ystem with an external OS.If the issue remains same then probably the issue is with Logic board.If the system doesnot gets shutdown autometically after checking with external os then u need to format the HDD and then install OS freshly.The issue will get solved
Apr 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My computer system doesnot play sound
Its not difficult. First of all, right click my computer and click properties. Then go to hardware and then to device manager. If your media player is showing error that the driver is not found, then it will show red/yellow mark at "sound video and game controllers". If it is red/green, right click it and select update driver. It will ask for motherboard cd. insert the cd, the computer will automatically take the required driver. Then its is done.
Jan 13, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear 2GB memory corruption
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
Philips Go Gear 2GB
Look for the slide switch on the side of the player and turn it off.
Aug 14, 2008 | Philips GoGear SA178 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
331 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
