Question about Ricoh Office Equipment & Supplies
We are using mp2851 ricoh copier in SAP 4.0, so please help to configure the print output comes to different tray. that means from tray1, tray2, tray3, and tray4
CopierOne
  • 30 Answers
SOURCE: repair of xerox copier 5334
Most of the time this indication comes from having a piece of paper lodged behind the paper drawer, blocking the paper drawer sensor, giving this indication. Remove the paper drawer and look into the cavity and you should be able to see the paper and remove it.
Posted on Sep 13, 2007
CopierOne
  • 30 Answers
SOURCE: Ricoh 1035 - Tray 4
There is a wire harness that connects the two bottom trays to the main machine. The connector might be loose or have a break in the harness. The main machine is not seeing the bottom two trays. Let me know if this helps.
Posted on Sep 15, 2007
jaylex
  • 417 Answers
SOURCE: Problem While printing
Hi there it seems to me that you have the printer driver set incorrectly.
First on the computer click on
Start
Then Control panel
Printers and Faxes
once in there right hand click on the pinter and select printing preferences.
Select the tray you wish to use as your default. Ok and exit that.
On the printer press the green tick button move the up or down arrow until paper handling is displayed. Select which feed either cassette or MP then sizes for this tray. Once that is complete select what media type the paper is i.e. plain preprinted or others.
(You may have to do that in the printing preferences within the driver as well)
That all going well you should now be able to press the print button and the page will come out from where you asked it from and with out pressing any buttons.
Hope this was of some help.
J
Posted on Dec 27, 2007
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
  • 523 Answers
SOURCE: Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Posted on Mar 24, 2009
Mp2000l .iwant to connect it to computer but cant. use all of drivers in the net but cant print.system win10 64 bit and using usb2 cable.please help.thanks
if u can't print via usb print by using an ethernet cable and putting a static ip to the machine and install the correct driver
get the driver at
http://support.ricoh.com/bb/html/dr_ut_e/re/model/mp16/mp16da.htm
please select proper driver of the operating system and if it helps let me know or if u don't understand something
thanks
Nov 26, 2016 | Ricoh Aficio Office Equipment & Supplies
What is the setting and/or fix for no prompt at tray 1 for special media?
Set tray 1 paper size to "any size/any type". print out a configuration page to make sure that this setting took. set manual feed prompt to " unless loaded". That should work. Good luck !
May 14, 2014 | HP LaserJet P4014n Printer
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
I have a HP CP2025 that will not pick up the paper from tray2 or print from tray1. It will pull the paper in from tray1, but it jams at the rear of the printer. It sounds like the printer is trying to pick...
It sounds like a blockage in the paper path at the rear of the unit. This unit picks from the rear of tray 2, and there is a separate path for tray 1 that conveys the paper above that tray and back to where it can intersect the main paper path. Sounds like you have a blockage where those 2 paths intersect.
Remove the cassette 2, and in that hole, there are 2 levers that allow you to lower the bottom half of the tray 1 bypass path. Look back in there for the tiniest scrap of paper left behind.
Next, if nothing is found, open the rear door, and again with a flashlight, look down in the bottom of the paper path for a small bit of torn paper, or some other obstruction. Odds are this is your problem.
Feb 28, 2011 | HP Laserjet Cp2025n Printer
Procedure to activate auto Tray switching in hp laserjet 4100
Okay, do you mean "Tray Linking". The process where, for example, if Tray1 goes to an empty condition, tray2 so the print job runs uninterrupted?
Or do you mean that you want Tray1 to print 6 or so pages and then switch to tray two because you need a different style of paper.
Tray Linking - you use the printer setup to activate.
Switch Trays - Usually controlled by printer escape codes.
If you create a "Print To File" off of the driver page, and send it to me at don.farr@hotmail .com I can look at the file and see what you are doing.
Don
Dec 08, 2009 | Office Equipment & Supplies
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
