For some reason my archos 605 wi-fi will not record from tv. Has been okay since I bought it some 4 months ago. Comes up with corrupted file or similar thanks Jim
Thank you very much for your e-mail.
I have been in the habit of just suspending my Archos between use. Problem was solved by simply turning the Archos off completely. On switch on, recording worked perfectly.
Thankyou for your help
Jim
Posted on Aug 06, 2008
Copying Video from archos 605 wifi to computer
I think the Archos 605 has a 2gb file limit, so the only option would be to split the avi.
Search on Google for an avi splitter - there are some free ones out there.
May 06, 2009 | Archos 605 WiFi Digital Media Player
Archos recording corrupted when battery died
There is no solution to this problem i am sorry but you will have to record it over i asked the Archos company themselves and their is no solution
Feb 09, 2009 | Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos 605 wi /fi only puts music on hard drive
A couple things to note. First.
Make sure the files are the right format.
second, make sure they are in the music folder.
third... sometimes it won't read them. you can still play them here's how:
Go on your archos go to music, than at the bottom click on hard drive.... you can play everything there.... i recommend not synching it... but dragging and dropping them in by hand... i like doing things basic...
Dec 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Archdfios 605 wi
mine's just gone a similar way - made a playlist and saved it...all songs were playing ok up until then. When i went to play the playlist it told me that the file was corrupt then proceeded to tell me all 14000 songs were corrupt...just in the middle of an attempted repair!
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wi fi fault
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
Nov 20, 2007 | Archos 605 Digital Media Player
Corrupted files
this happened to me aswel........
you have to download all your songs back onto your archos and will work fine after that
you may have to delete the songs off first.... i just synched it with my windows media player on my laptop.
Sep 21, 2007 | Archos 605 Digital Media Player
 Grubhead
Grubhead
