Question about Promaster 7400EDF Flash for Canon EOS
Getting the promaster 7400edf flash to meter properly with canon eos 60d
  • 747 Answers
The flash model for Canon is 7308 it might be the correct flash but programed for the wrong brand/manufacture. The way I see this flash is that Promaster produces this 7400edf to work on all the major camera brands but it's programed for a specific camera. The flash firmware updatability is done by a dealer. Another thing I ran into with one of my students cameras (a Canon) was you needed to go into the menu to select external flash over internal. I believe Canon is doing this due to the video capabilities of the camera.
Posted on Apr 18, 2011
The flash on my canon eos 60d not working
Possibly the spring that raises it is broken, or there is foreign matter in the hinge. Can it be raised manually ?
Oct 03, 2016 | Canon EOS 60D Digital Camera
Red focus squares show on pictures
Disable the "AF Point Display" in the menu.
If you need a manual, you may download a copy at Owners Manual User Guide for Canon EOS 60D Digital Camera EOS60D pdf
Sep 25, 2016 | Canon EOS 60D Digital Camera
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Is it ok to use a promaster 7000m flash with a canon eos t1i? I don't want to damage the camera.
Yes, the Promaster 700M, with its trigger voltage of about 3 volts, is safe to use with modern digital cameras.
Mar 06, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My new canon eos 60d will not format my new promaster memory card, Message keeps coming back " system busy please wait" did it four times and waited over 30 mins per time
The 60D unlike it's predecessors uses an SD/SDHC card I'm not familiar with the "Promaster" brand of memory card but what all SD cards has is a little lock on the side it's a little white switch that needs to be slide forward to the top of the card to unlock. Once done the card should perform the same way as a Compact Flash card.
If this is not the problem I would suspect a faulty card
Dec 28, 2010 | Canon EOS 60D Digital Camera with 18-200mm...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in flash to pop out when needed.
I have tried turning the power off and on again. The problem persists.
Dec 19, 2010 | Canon EOS 60D Digital Camera
An English copy of the Canon EOS 60D Manuel: I
You can download the manual and more from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_60d#BrochuresAndManuals
Oct 11, 2010 | Canon EOS 60D Digital Camera with 18135mm...
Promaster 7400EDF Flash for Canon EOS Logo
193 people viewed this question
Top Promaster Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Promaster Camera Expert? Answer questions, earn points and help others
