Question about Microsoft Flight Simulator 2000 Professional for Windows
On fs2000 only gets to scenery mode on cd 2 then freezes xp. on vista does not load anything
Have tried all possible "F" button start up options. Will not recognize vista dvd. When loading safe mode, stops loading drivers and freezes. Cant get to anything but Bios. All other options are ask
Some BIOS use other keys like the ESC key. It should be noted on the screen during boot. Plus some have an adhoc boot one time boot menu.
You could also make sure the CD is bootable on another pc.
Jan 26, 2013 | Computers & Internet
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
The flash on my camera will not turn on no matter what I do. The flash button won't bring up a flash menu or anything. Any suggestions?
Flash is deactivated in motion picture mode, scenery, night scenery, sunset, highsens, starry sky, fireworks or aerial photo in scene mode.
Jul 23, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Getting ERROR FOR OPERATING SYSTEM
This is because you have to change the boot sequence in the BIOS or setup of the motherboard. When you first turn on the computer you can see something like press DEL to enter Setup or F12 or F10 or F2 depending onyour motherboard. once you get into setup you will see either boot sequence or boot order. Set the CDROM as the first boot device. Then when you startup the computer again you will see PRESS ANY KEY TO BOOT FROM CD. proceed with pressing anything on the keyboard.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Installing xp freezes
If it will only boot in safe mode it means you have a driver conflict.
This is only a suggestion but try fresh reinstalling windows, with only basic xp drivers then install other drivers one at a time rebooting each time you do until you come across the faulty one. remove it or check its for xp not vista research net for correct one
Jul 17, 2008 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
Presario v4000 will not boot up
hi,, this compaq is fucking,,,,,,,, even i got the same problem
Oct 31, 2007 | Compaq Presario V4000 Notebook
Installation cd
There is no driver available for the C46 that supports Vista.
You will either need to replace the printer, get a genius to write a driver you, or you could TRY getting vista to run the driver in compatibility mode for XP.
I do not use Vista and so the following could be a comp0lete load of old tosh, but...
In XP if you right click on the .exe file and select Properties, then head for the computability tab, you can choose to run an .exe as if you were using a different version of windows.
I don't know if Uncle Bill has retained this feature in Vista but if he has it's worth a shot. If you are running a 64bit version, I think you are pretty much up a gum tree as there are no 64 bit drivers anywhere for anything.
Oct 05, 2007 | Epson Stylus C46 InkJet Printer
Microsoft Flight Simulator 2000 Professional for Windows Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
