Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
When removing the bottom tray for cleaning, I have found that my Saeco Vienna De Luxe Espresso is leaking a small amount of water. I believe it is coming from the grinder as the water is pooling under the grinder. I have not noticed any other appreciable difference in the production except it may be noisier. We love this machine and have a number of friends who also have various models. They feel the same about their Saeco Vienna De Luxe Espresso makers. Thanks
  • Anonymous Sep 01, 2008
    I have the same problem with considerable amount of water and coffee ground under the tray. Instead of dripping into the tray, it now fills up behind the block unit and underneath the tray.
  • 515 Answers
It can be the steam valve or the boiler that is leaking.
Posted on Aug 06, 2008
My Saeco Vienna Deluxe has water leaking out from somewhere underneath - clear water.
There are so many places to check, but lets check the small chamber under the white plastic valve, which sits behind the brew unit, clean out the chamber of coffee grounds. If that is not the cause then, you will have to open the machine to find the leak.
Feb 17, 2010 | Saeco Vienna De Luxe Espresso Machine
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
After coffee is made, clean water leaks out the bottom.
Remove the brew unit, find the white plastic valve inside, look under the valve you will see a small chamber, with a discharge going into the drain tray, clean out chamber and discharge.
Jun 27, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Liquid leak while Vienna runs...but where from?
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Feb 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Diverting all of the coffee flow into the bottom tray rather than the cup.
You might want to check and clean the coffee outflow spout ( the adjustable double spout on the outside of the machine) . If it is all plucked up that might be the cause.
Sep 09, 2008 | Saeco Vienna De Luxe Espresso Machine
You can download a manual at
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
657 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
