Question about Ovens
IT SMELLS LIKE OLD CURRY WHEN WE MOVED INTHATS WHAT THE PEOPLE TOLD US
    Problem Solver:
  • 4 Answers
Place a tray filled with white vinegar into the oven. Turn it on to a medium-high heat and let the vinegar "cook off" or reduce to 20% of its original volume.
Yes, you will smell the vinegar and the oven will smell like vinegar- but that's the best way to clean a smelly oven. I prefer the vinegar smell to that of curry, burned meat,etc.
DO NOT REMOVE THE HOT TRY- TURN THE OVEN OFF and wait for the oven to become cold, then remove the tray/pan and remaining vinegar - then clean the oven.
Posted on Apr 05, 2011
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
What is wrong with oven
It sounds and smells like and element or wire or connection popped.
Sep 21, 2014 | Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
Nov 13, 2013 | KitchenAid Architect Series KEMC308KSS...
I have recently moved into a new house and can't get the oven to work. I was hoping to get a manual for the wall oven and see if this information will solve my problem. It is a 1993 model EVBS3193...
So you have moved to a new house. I am assumeing that the Oven worked fine at the old house. I am also assumeing that you have plugged the Oven into your new house and that is when you noticed that it was not working.
If this is the case then the problem may be that the Breaker in the Electrical Sevice Panel of the new house is off. You need to reset the breaker and the Oven should then work.
Jun 12, 2011 | Ovens
Whirlpool AVM 683 IX even thought i use my microwave with microwave plates or plastic containers, it starts to make sparks and the light flashes, also there is a dull noise. The microwave is not that...
Hi, do you still have this microwave? For the case you want to throw it away: may I kindly ask you to leave the mounting frame to me? I do posess the same machine (bought with my kitchen in 2001), built in my kitchen board. When we moved last year, the workers who teared down the kitchen furniture, broke a part of the frame. Since than, I have asked in many places if it is possible to buy this part of the frame, but only found one shop. There I was told that I have to buy the complete frame, and it is so expensive that I flinched from buying it. So my idea is that I will pay you for the frame, if you agree with this.
Please contact me for further information. Thanks in advance!
Gabriele
Oct 16, 2010 | Whirlpool Ovens
SA999X wont turn off & smells
suspect your electrician wired it up wrong
Feb 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
233 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
