Question about Intel Computers & Internet
My lga 775 is swichtching on even switch, reset are disconected in mother board, and when swicth is connected even with out switching it swicthing on automaticaly but never off unless turn off the avr or unplug it, no display also because it shutdown imidiately but the unit is stil on working
    Habit-Forming:
  • 23 Answers
If this is a new board, contact the store you purchased it from. You should be able to get a replacement if you just bought it and it hasn't been shorted out by something during installation.
If they will not take it back, use the return instructions on instructions that came with the board to get an RMA (Return Material Authorization) number. This will be your company approved authorization to return the board.
If it's an old board, it's probably time to upgrade or try to get a good replacement if your processor is still good.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
Posted on Apr 05, 2011
Pye awm800 drains water but wont spin. any idea as to the cause please
The timer swicth needs to be replaced. Part of the time swicth that controls the spinnig is bad.replace timer swicth and that will fix your problem
Apr 09, 2012 | Washing Machines
Replace ligth swicth dimmer swicth brakes and singal litghs work no head ligths
Sounds like your turn signal switch is bad!! Multi-functioning switch it controls your head lights two? Unless you have a push button switch!
Sep 04, 2011 | Chevrolet Chevy Cars & Trucks
Power button not working, no resistance on swith?
You need to replace power switch if they did not contact.What swicth is the deffect,the main swicth or the tack swicth the second power?
Jul 04, 2011 | Televison & Video
I have a 2003 envoy. The driver side window swicth does not work, but the door lock and window lock works. and the other door window swicth also work.
You may have a loose connection on the window switch or it could be corroded or the wire may be cut or shorted. You have to get to the switch to check it out.
Apr 21, 2011 | 2003 GMC Envoy
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Solve Your Asrock Pentium 4 (LGA 775-pin) - 4Core1333-Viiv M/board - P965, 1333MHz FSB, Dual DDR2-800, PCI-Expr... Motherboard Problem Now!
Remove the CMOS battery from mother board and hold down the power switch for 5 minutes ,install the battery again.You also check the ram, to your another pc .If the RAM is defected, change it, as a new if you have a spare.
http://www.youtube.com/watch?v=3B9ff9ei7hk
If you face the same problem please install a another well SMPS power full.
http://en.kioskea.net/faq/7125-flash-getplus-r-operating-system-error
Hope this helps.
Jan 11, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Chassis intruded ! fatal error...system halted
Your computer BIOS should have an option to turn this off.
Or you can probably place a jumper on the mother board so the "tamper switch" is always closed.
Consult your motherboard manual for more info.
Jul 11, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
How do you replace headlight swicth?
remove the top and bottom steering wheel column covers then push on lock tabs at top and bottom of switch assembly while then slidding out PULL then disconect wiring from swicth.
Jul 09, 2009 | 2002 Daewoo Nubira
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Computers & Internet Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
