Question about RCA HD52W59 HDTV Projection Television
I have a 32" RCA
    Top Expert:
  • RCA Master
  • 75,452 Answers
Hello
According to you, your RCA TV has went off while watching it. As there is no sound or picture at all, and the power kicks, the fault must be to its horizontal out section. The horizontal output section have LOT [Line Output Transformer] and related parts in it. Your TV must be chcked well to detect the actua fault. Normally, the LOT said above can be faulty, otherwise, the horizontal output transistor, the device that drive the LOT may also damaged. If this transistor gets leaky, the secondary main power DC supply will get a direct short, and the set will come on protection mode as we switch it ON. Here, according to you, this is happening. Just replace the horizontal output transistor first and see the effect. It is a three terminal component, screwed on to a metal heatsink, and can be located very near to the above said LOT.
After replacing it, switch On your TV, for a while, say 5 seconds or so, and if a whisiling sound is heard, and the replaced transistor over heats, the LOT said above is faulty, and should be replaced with same type and number. OK.
Posted on Apr 05, 2011
  • 2 more comments
  • nehemiahsmom Apr 05, 2011
    ok thanx sound like i should just get a new tv haha. is this a easy/ cheap fix? its of course not the tv as the headline says.. that was an accident, i dont know how it said that tv.
  • The Knight
    The Knight Apr 05, 2011
    Whichever may the TVis yours, the fault you indicates is this. This is a common fault for most of the TVs, and can be fixed. But to fix it by yoursef, you must have a sound knoledge in electronics, concept of soldering and testing equipments. Otherwise it is best to get it repaired by any experienced service technicialn. It will not cost a lot as you expects. Lot is one which cost more, the transistor I said above is a little bit cheap. OK.
  • The Knight
    Sir
    Just replace its horizontal output transistor first. It can be located very near to the LOT, screwed on to a metal heatsink. It it a three termimal component, black in colour. After replacing it, switch on your TV, for a short time, say 3 seconds or so, and feel the heat effect of that transistor, by hand, after unplug the set from AC mains wall socket. it can be warm, but not over heated. If LOT has shorted, this transistor will overheat in short time, and a whisiling sound or any unusual high frequency sound will be hear. If so, make sure that the LOT is faulty, and it also should be replaced with same type and number. OK.
  • The Knight
    The Knight Apr 06, 2011
    Sir
    I here gets a comment notification signal from you, but nothing seems to have typed. Please send if any. OK.
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
My Sanyo TV was plugged in, I was watching it and all the sudden the screen went gray wash, then it cut off. You can plug it in the wall and it will try to cut on but cuts off after like 2 seconds. It also...
U have a soldering iron,solder?Now basic soldering?Unplug the tv wait about half an hour for the highvoltage to disapear.Take the tv aparts.Resolders the Video board that connected to ur CRT Tv tube.Resolders all those coldsolders pins sockets pins on the video board,will solved this problem.Have fixing these problems many times on the CRT Tube computer monitors,when it was still popular.
Sep 09, 2010 | Sanyo Televison & Video
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
Have a rca, sdtv, 32", screen stopped working.
Nope, you have a bad part inside.
It's fix or replace time.
Jan 06, 2010 | Televison & Video
RCA TruFlat 32" Blue light flickers, clicking noises, help!
OK for the start, try this unplugged your unit for about 60 sec. Then plugged it again and switch on. Does it help?
If not then dont connect your surge protector in line for the meantime. Power the unit. This is to isolate whether your surge protector is defective or not. Does it help?
If not, this could down to your high voltage section, if this is a crt tube tv. You might loose your flyback transformer, and or the horizontal output transistor. Checking its peripheral component is a must. That clicking noise is the relay, thus this have relay?
If your not into electronic, have it service.
Apr 28, 2009 | RCA TruFlat 27F520T 27" TV
My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Nov 30, 2008 | RCA F32650 32" TV
Broken TV
the solution to fix you tv is replace broken video cable tv obviosly cant find an input.
Aug 25, 2008 | RCA F32650 32" TV
RCA 32
this problem may occur due to some drysoldering of some components on the mother board...mostly in the power supply section.
Jul 09, 2008 | RCA F32450 32" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
RCA HD52W59 HDTV Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
