Question about Fuji Office Equipment & Supplies
Hi, can a xerox 3030 be dismantled for relocation. Is the base removeable?
What is the procedure for dismantling a Xerox 5665 developer unit which is faulty?
That unit is a consumable, you're not supposed to dismantle it.
Dec 18, 2014 | Xerox 5665 Copier
How do I dismantle the base unit from the xerox workcenter 7655
Look inside the left hand side door ( stacker unit)
the unit is locked onto the side panel with a sliding bracket. Look for a thumb metal bracket and push it to release the stacker unit.
normally these units aspire very reliable. Undo the unit and the interconnections then slide apart.
Good Luck.
Oct 02, 2014 | Xerox WorkCentre 7665 Copier
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
May 11, 2012 | Xerox Office Equipment & Supplies
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
Have to relocate zerox 240 up several flights of stairs. last time I did it, xerox charged me hundreds to just have it restart. What is the proper way to shut it down and restart etc.
Hi, there is no real way of shutting these down, but if you remove the fuser and take the machine up from the back you will be fine. Just don't tip it to far backwards. We do these all the time and have had no problems so far.
Paul.
http://www.xerographic.co.uk
Aug 21, 2009 | Xerox DocuColor 240 All-In-One Laser...
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
SQ FT meter reading
METER A is the square feet. METER B is linear feet
Jun 12, 2008 | Xerox Office Equipment & Supplies
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
