Question about Remington R4130 Hair Trimmer
Do the replacement blades pack for the Remington R4130 come with the plastic parts that hold the blade in place it's like a cup and attaches with two plastic hooks to the main plastic frame that hold the blades.
  • Remington Master
  • 1,610 Answers
You will find this head assembly with blades and holder at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Posted on Apr 05, 2011
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
I have a remington R4130, when I opened the package the head came off. I cannot get the top part with the wire to lock in place, any idea how I get it to lock in place?
The wire hinge is a weak point, and my Remington R4130 head also detached at the same point. Getting one side of the wire back into the hinge hole was easy, but to get the other side into the hole (located at the center of the back edge), I needed to use a needle-nose pliers to grab the bent end of the wire and direct the pointed end of the wire into the hinge hole.
Jan 09, 2011 | Remington R4130 Hair Trimmer
Remington 5130 battery is fully charged and when you put it on it goes click. I noticed that one of the heads moves when you try ot turn it on. Removed that head on the unit works great. Put it back it...
It sounds like either the heads are packed full of hair particles and the blades can not turn OR one of the blades has been damaged and is causing it to lock up.
Try removing all of the blades and cleaning them thoroughly and also insoect the blades, particularly the one that moves when you turn it on
If replacements are required, you will find them at shaveroutlet.com. See link below
Dec 08, 2010 | Remington R5130
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Remington R4130 Hair Trimmer Logo
214 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
