Question about Whirlpool WMH1162XVS Microwave Oven
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
  • Whirlpool Master
  • 6,771 Answers
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Posted on Apr 05, 2011
There is nothing on the display. The unit is dead. Help?
Posted on Jun 10, 2011
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 13, 2013 | Microwave Ovens
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
Sharp microwave door will not shut and the oven light stays on continuously.
The door has a switch , probably two, that engage and disengage when opening or closing. ( a failsafe so it switches off ) when you open the door, this is the problem also like a fridge the light should go off when door is shut, it may just be stuck but Dont mess with it , clean it if its got food stuff , a mild detergent round door etc , otherwise just change microwave ,
pete
Nov 10, 2010 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Microwave lights up but does not heat or turn table when start button is pushed
Check your door interlock switch. Unplug the device, remove the cover DO NOT TOUCH THE SILVER CAN - POTENTIALLY LETHAL. Locate the small, probably black micro switch. Test it with a volt/ohm meter or other contunity tester. It should read "closed" when the door is closed and "open" when the door is open.
If you are like me, you turn the machine off by opening the door. When you do this, power sparks between the small contacts in the micro switch and eventually burns them up. When this happens, the machine thinks the door is open and will not turn on the magnatron - thus - no heat.
Find a replacement switch at a electronics or appliance parts place. You may have to provide make and model for an exact replacement. If you are handy, you can adapt any regular micro switch.
Let me know if this works for you.
A
Sep 14, 2009 | Microwave Ovens
MICROWAVE WILL NOT HEAT FOOD AND TIMES OUT @ 30SEC'S
Replace the magnetron and the wave guide.
May 14, 2009 | Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Turntable continues to rotate.
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Yahoo search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please post again. Be safe!
Oct 29, 2006 | Panasonic NN-S264BF 1200 Watts Microwave...
Whirlpool WMH1162XVS Microwave Oven Logo
200 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
