Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Black screen The screen briefly flashed print when plugged in, then went to black screen. The monitor light is green, and the AC Adapter light is also green.
  • Anonymous Aug 10, 2008
    Same problem as others on this post. Screen will work for one to two seconds and flash off. Hit auto button and the same thing will occur.
    Need help!
My display , a year old, when turned on flashed correct screen on for a second and went dark each time. (green light stayed on).
I tried a different power cord with about the same rating (12vdc at 4amps). It solved my problem. Perhaps it will solve yours as well.
I used a power cord from one of my AA/AAA battery chargers rated 12v at 3.0 amps
Posted on Oct 27, 2008
    Champion:
  • 293 Answers
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Posted on Aug 12, 2008
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Screen is black. green light on ac adapter blinks briefly about every 2 seconds
Look for bad solder joints in the inverter circuits, look at the round inductors (4) leads soldered to the circuit board, post or send pictures for futher help.
Feb 02, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a black screen with the power light off but
The monitor does dot but the ac adapter does. The adapter has an automatic overload and thermal protection circuit built in. You can try plugging it into a surge strip and see if this stops it or putting the adapter where it can stay cooler. Some people have put a small fan blowing on it. They often do this and it is usually because the adapter is getting too hot. Don't put it in an enclosed space where it has no air flow. It is designed that way to keep the adapter from failing and having to be replaced. Hope this helps you.
Mar 29, 2009 | HP Computers & Internet
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Monitor went black completely dead
Hi...there,
A simple way to check your AC Adapter, plugged into a socket and see if it lite green... If you don't see a green light lite on the AC Adapter, then it's DEAD... You can order the AC Adapter @ www.3rd-rocks.com but sometime you need to replaced both. Have a nice day!
Nov 17, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
536 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
