Question about EliteGroup P4VMM2 Motherboard
Hello, I'm trying to track down a USB driver for a Freecom FHD-1 external drive to run under Windows 98se (for the moment). Have checked freecom.com for drivers but am a bit dizzy after that. Issues would see that 98se is USB1.1 and the Freecom expects v2.0 but Freecom states it will accept v1.1 i/o. Did read that it is possible to upadate 98se to the USB v2.0 of Win ME. I may have to try that. However, in the mean time does anyone know where a driver can be found for this FHD-1 external drive. thanks for any help and suggestions offered. regards, Kev
    Sergeant:
    Champion:
  • 217 Answers
Http://support.microsoft.com/kb/263218
Some info on 98se and USB issues. You should not need a usb driver if the usb port in your computer is already functioning properly. The only inconvenience you will have is your drive will work at the slower speed provided by the usb 1.1 standard.
The link below describes step by step installation of your drive in 98se
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/FHD1.pdf
Posted on Apr 05, 2011
Hard disk USB does not connect
Have you tried reinstalling the drivers? Go into hardware and uninstall ththe device there then reinstal it again, drivers and all. Thats the first thing I would do...
Jul 05, 2012 | Freecom FHD 1 120 GB USB 20 Hard Drive
I need a USB driver for Windows 98SE to use a flash memory pen.
To my knowledge, most flashdrives comes with an installer mini CD that contains the Windows98 drivers. Should this no longer be available, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 29, 2008 | Electronics - Others
Hi there i have a freecom 1T external hard drive, i have plugged it into my laptop, and a message comes up saying that the device has malfunctioned and that windows does not recognise it, code 43, can u...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa.
May 22, 2011 | Freecom Office Equipment & Supplies
My laptop doesn't recognize my 80gb harddisk. The light goes on but it down't show in My Computer or anything. What can I do?
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 18, 2011 | Freecom 80 GB USB 2.0 Hard Drive
I need to intall a freecom usb external hard disk to an old computer uses windows 98 an i havent a drive Any help please? How can download s driver for this disk?
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
I wish that I could be of more help.
Nov 13, 2010 | Freecom 80 GB USB 2.0 Hard Drive
WD Element 1 TB on Windows 98SE system
You can NOT access 1TB under Win 98SE, It is unable to "Address" that much memory, it is simply mathematically impossible. You have to upgrade to a system that CAN address that much memory, such as a 32 Bit system. better still a 64 bit system.
Mar 03, 2010 | Computers & Internet
Freecom external 80GB drive not detected by Windows
go to the freecom web site and download the drive for that unit after that the computer will see and connect to the unit
Oct 24, 2017 | Electronics - Others
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
INdex.dat causing bail-out of HDD Back-up
Index.dat is not required, simply do not include it in your backup..windows will recreate the file automatically. It is created by the file indexing service for faster searches, etc.
Cheers,
Flyback
Apr 19, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
96 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
