Question about Sony Televison & Video
Sony mdp -500 wont stay powerd on - Sony Televison & Video
  • Sony Master
  • 2,098 Answers
Hi xcellpro,
Try to reset the unit. Unplug it to the outlet. While unplug, press the power on button for 1 minute to drain the unit and refresh itself. After that plug it now to the outlet then power it on again and check if the symptom is still there.
If yes, this is an indication of out-of regulation in the power supply section or to its load. The power supply cycles on abnormal output voltages that caused with its parts malfunction or because of overload in its load.
Power supply malfunction was commonly caused by bad filter electrolytic capacitor, open fusible resistor, shorted transistor.
Load malfunction was commonly caused by shorted pre-amplifier IC, or shorted main output IC.
This symptom is quite technical and I would advice you to look for an experienced technician to isolate the trouble. Don't attempt to work in the power supply section if you don't have necessary tools and test instrument and don't know safety precaution of handling it. There some stored electricity that may hurt you with just a little mistake only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 05, 2011
Wont dstay powerd on by self and says a custom o.s. can cause critical problems in tablet and installed apps.
Noocube Brain functions may be enhanced through the foods that people eat. There are certain nutrients that are inside various types of food that may help mind to work better especially in storing and in retrieving information. There have ended up studies that were made on the effects of vitamins and other nutrients on the cognitive functions and abilities. Some nuts like almonds as well as hazelnuts have vitamin e d-alpha. This is needed if the body and relaxation healthy.
more info >> http://phytolyft.com/noocube/
Apr 25, 2016 | Tablets & eReaders
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
WHY MY TV WONT STAY POWERD ON
Most modern electronic devices, have safety switches. When something is getting to hot, or needs to much current, or gets an over voltage, it will cause the power to shut down. Sometimes just a defective capacitor or a semiconductor will do the same. Like most doctors can't tell what is wrong, unless they see the patient, it is almost impossible to tell you what is wrong, without seeing the thing myself.
Perhaps you ask a repair shop close to you, what it will cost to do the diagnose and what it will cost to repair?
Oct 27, 2014 | Element ELCHW321 32-Inch Class 720p 60Hz...
I cant get sat nav to stay powerd on in the car.willpower up on computer but wont stay charged
Any time the unit will not stay powered after an external power source has been removed is an indication that the battery is failing. A Nuvi 205 is a pretty old unit. If the battery has never been changediast2 years, I would recommend having it replaced. info here:
http://www.sharc.net/gps_battery_repair.htm
Oct 02, 2013 | Garmin nuvi 205 GPS Receiver
My deck wont stayed powerd up
Remove the unit and check to see that you are getting a solid ground. Be sure to check that there is no bare wire that is causing a short
Nov 25, 2010 | Audiovox PAV-1510DTV Car DVD Player
Green and red ligts flash when powerd up also
hello there's a couple of things that could be wrong .the high pitch noise could be the convegance chip shorted out these are 2 big black chips connected to a metal frame called a heatsink the other could be the lamp burn't out
shaun
Oct 21, 2009 | Sony Grand WEGA KF50SX300 50" Television
Mdp 1760 - car adaptor wont work-universal quit also
I have a power cord that belonged to mine. My player quit working. You can email me at quartermiledr@yahoo.com and we can make some arrangements if you are interested.
Jan 06, 2009 | Mintek MDP-1760 Portable DVD Player
Mintek MDP-1760
My Mintek MDP-1760 try to loading the dik and later show a mesage NO DISC... what is the proble?
Jan 30, 2008 | Mintek MDP-1760 Portable DVD Player
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
