Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba # KSCS25
Ice maker quit working - I turned the switch to off and tried to remove the ice maker, I never got it out so I truned the switch back to on and it started working,
it made one good batch and now it's back to not working....I wonder if the line is frozen and unfroze while I was trying to pull that sob out of there? I have the freezer set to 0 as reccomended. Should I set the temp. higher? any suggestions?
Thanks!
  • badfridge Aug 27, 2008
    piece of **** has never worked and destroyed ice maker brackets trying to get it out because it worked intermittently freezer wont go below 6 deg. and always runs
  • 283 Answers
Check the disconnect plug for power and good connection. Check the ambient temperature-colder the better but should be below 15 degrees. If the arm is down and all else OK replace the unit. Those IM's are throw away items now.
Posted on Aug 06, 2008
Ice Maker will not stop making ice
On Your KitchenAid Superba they use an electric eye receiver board part# 4389102. You might want to try cleaning your icebin and the electric eye to see if that works first.http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 27, 2012 | KitchenAid Superba Architect KSCS25INSS...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
vcb
Aug 08, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Oct 18, 2007 | KitchenAid KSRS25IL Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
308 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
