Question about Whirlpool Washing Machines
My washing machine has 2 parts in its cycle where I need to manually move the control knob to the next setting as it's stalled. Is this fixable?
    Sergeant:
    Champion:
  • 218 Answers
You will need to replace the timer see your local appliance repair shop for the parts?
Posted on Apr 05, 2011
Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Jun 18, 2009 | Kenmore Washing Machines
Washer will not go onto next cycle
Timer control is bad needs replaced
85 -100 dollars
Jun 02, 2009 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Kenmore Fabric Care 90 won't stop washing
It sounds like your timer motor may have died. Pull the knobs off the controls and remove the screws in the control panel to get to the motor. The motor is usually pretty expensive, so you might want to consider buying a new washer over replacing the timer motor.
Apr 18, 2009 | Kenmore 22422 Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Maytag Washer never stops running, goes from 1 cycle to the next
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible.
If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Sep 03, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
